Strat's Car |
Strat's Car |
Gulf91474 |
Sep 13 2016, 10:34 AM
Member Group: Members Posts: 53 Joined: 3-April 15 From: salt lake city utah Member No.: 18,591 Region Association: Intermountain Region |
total bummer......Gald you still had a fun weekend..... (IMG:style_emoticons/default/blink.gif)
veekry9 |
Sep 13 2016, 11:13 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Bummer,man. (IMG:style_emoticons/default/unsure.gif) 'Engine seems a quarter down on power' This is my piston.There are many pistons like it,but this one is mine. (IMG:style_emoticons/default/mad.gif) What was the fuel being used at the time of failure?<- Has the head been inspected for cracking due to the temp spike? Have the exhaust valve seats become loose? Have the exhaust valves been cracked from the high egt? Have any of the other cylinders been damaged by the shrapnel? Half the time the rod gets loose from the piston and flails around in the crankcase . http://www.914world.com/bbs2/index.php?sho...293242&st=0 http://www.vw-resource.com/octane.html http://www.dtic.mil/dtic/tr/fulltext/u2/b807149.pdf http://www.contactmagazine.com/Issue54/EngineBasics.html http://diversiorum.org/sape/pilotage/Engines/index.html Mix/Load/rpm/air temp/altitude. / |
jim_hoyland |
Sep 13 2016, 11:41 AM
Get that VIN ? Group: Members Posts: 9,258 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Not knowing the situation, this could have been a lot worse. What do the valves and head look like? Maybe you need just one new jug? I hope you can post a complete autopsy; pics, details, causes. And the extent of replacement parts. Maybe we can learn something from this Of course, it was great Jim carried on and made the RRC anyway. |
Eric_Shea |
Sep 13 2016, 06:13 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Injectors are being tested now. Report back tomorrow.
New 123 dizzy was set at 27 degrees exactly. I'm hoping the injectors tell a story. They all tested good prior to install. I'd hate to have a problem with the 123. I may take it to Ed Fall and have him double check the curve. The rest of the motor looks great. It doesn't look to have gotten that hot. Heads and other pistons still look new. |
Catorse |
Sep 13 2016, 08:12 PM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
That's what you call a piston squirter :-)
jim_hoyland |
Sep 13 2016, 08:44 PM
green914 |
Sep 14 2016, 07:34 AM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/barf.gif) That looks awful. Glad you still made it to RRC (IMG:style_emoticons/default/smoke.gif)
Claus Graf |
Sep 14 2016, 07:59 AM
Member Group: Members Posts: 51 Joined: 25-November 14 From: Houston, TX Member No.: 18,154 Region Association: None |
Expect low compression in that cylinder... (IMG:style_emoticons/default/sad.gif)
Mueller |
Sep 14 2016, 09:24 AM
Bummer, hope to read what the cause was here so it can be avoided by him and others!
Could have been worse....I was troubleshooting a friends car which wouldn't start for her. I had her crank over the motor while I stood over it looking around and there was a loud explosion as the cast aluminum valve cover blew apart, how I didn't get hit by chunks of sharp metal was amazing. Turns out one of the pistons had a hole in it and that cylinder finally lit and the combustion gases went thru the hole in the piston and found the weak spot which was the valve cover! |
Eric_Shea |
Sep 14 2016, 01:59 PM
Report from the injector shop came back just now. #3 down in volume and spraying a straight stream. It appears that's what holed Jimmy's KB.
JustinMeier |
Sep 14 2016, 02:02 PM
Member Group: Members Posts: 244 Joined: 3-August 16 From: Scottsdale Member No.: 20,258 Region Association: None |
I think he was seeing his doctor about the same issue.....
crash914 |
Sep 14 2016, 02:14 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Who do you use got injector service? Thus looks very much like what happened today my motor. I either lost an injector organizations it was clogged. Want go fix before I install on my new motor.
JamesM |
Sep 14 2016, 02:38 PM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
76-914 |
Sep 14 2016, 03:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,488 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
How about some details on your engine, Jimmy. Size, compression, modifications, engine hours, etc. What was the performance like up until it took a crap. Number 3 piston? (IMG:style_emoticons/default/popcorn[1].gif)
pete000 |
Sep 14 2016, 03:05 PM
That's a compression release!
Toast |
Sep 14 2016, 03:56 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
I think he was seeing his doctor about the same issue..... (IMG:style_emoticons/default/happy11.gif) Now that's...... |
StratPlayer |
Sep 14 2016, 05:17 PM
StratPlayer Group: Members Posts: 3,264 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Engine: Late model D-Jet, 2056, OEM cylinders bored out to 96 mm. Keith Black pistons, Hastings rings.... New 123 ignition, new bearings, etc. The car was running great, lots of pep. Motor had maybe 2K on it, never took it on any long runs, just around town. Freeway short distance.
This was the first real test of the new motor. One injector decided it had enough. fked up my piston. It could have been a lot worst. I have 4 new injectors, they will be going in the car. Bottom end being checked for any junk that might have gotten in there. It will be checked fully. Car will be up and running soon. Won't be long I'll put it to bed for the winter. |
veekry9 |
Sep 14 2016, 05:33 PM
Well,the fuel system has always been a no compromise repair,from rusty tank to aged plastic lines.
Lost a few 14s to the failure of any one part,and a single speck of debris that holed a piston. (IMG:style_emoticons/default/mad.gif) A total rebuild then,is the path to hassle free running,a cleanout and replacement of rubber lines that appear ok externally. An impressive hole and a lesson that warns those that might cut corners,'re+re your fuel system'. A fuel system depot for all your needs might earn a dime,globally. (IMG:style_emoticons/default/smile.gif) / |
76-914 |
Sep 15 2016, 09:30 AM
Engine: Late model D-Jet, 2056, OEM cylinders bored out to 65 mm. Keith Black pistons, Hastings rings.... New 123 ignition, new bearings, etc. The car was running great, lots of pep. Motor had maybe 2K on it, never took it on any long runs, just around town. Freeway short distance. This was the first real test of the new motor. One injector decided it had enough. fked up my piston. It could have been a lot worst. I have 4 new injectors, they will be going in the car. Bottom end being checked for any junk that might have gotten in there. It will be checked fully. Car will be up and running soon. Won't be long I'll put it to bed for the winter. Damn Bubba! Nothing but the best and this happens. Go figure. (IMG:style_emoticons/default/beerchug.gif) |
whitetwinturbo |
Sep 16 2016, 09:28 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
(IMG:style_emoticons/default/WTF.gif) .........that looks like SUPER LEAN under load
Lo-Fi Version | Time is now: 23rd April 2024 - 07:39 AM |
