| N_Jay |
Sep 13 2016, 07:18 PM
Member ![]() ![]() Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
I will be making up a few sets of nylon engine mounts.
These will be 2" diameter Nylon 6 rod cut to replace the front rubber mounts on a side-shift car. The set with all hardware from Jwest at AutoAtlanta are $37.50 and seem to be between $30 and $40 plus shipping other places. I am selling just the Nylon spacers but I figure the hardware is only between $6 and $10. One difference is I am cutting the nylon spacer to use a fender washer above and below. This will more evenly spread the load on the nylon compared to the Jwest design. I doubt there is anything wrong with their design, it just seems like a worthwhile improvement for the cost of 4 washers. Testing the water at $15 a set shipped in the US. Hardware needed: (Not provided) 2 Long 8mm bolts (or studs) 4 8mm x 24mm fender washers 2 (or 4) 8mm nuts, recommend nylocks or locking nuts 2 (or 4) 8mm lock or wavy washers |
Lo-Fi Version | Time is now: 13th March 2026 - 07:11 PM |
