2 Pages V < 1 2
> Charging Issue, revisited...., not the Voltage regulator
Bleyseng
post Apr 16 2005, 12:49 PM
Post #21
Aircooled Baby!
Does the lite get brighter as you add load to it? Turn on the headlites, fogs, heater fan, etc and see.
If that makes the light come on brighter then odds are a diode is going out as the Alt is just putting out part of its juice.
Geoff
Aaron Cox
post Apr 16 2005, 12:50 PM
Post #22
Professional Lawn Dart
QUOTE (Bleyseng @ Apr 16 2005, 11:49 AM)
Geoff
going to go check that now....
ws91420
post Apr 16 2005, 12:54 PM
Post #23
Yes I have one a Lensley 914
From: Ruther Glen,VA (halfway between sticks and civilization)
People read previous posts. His voltage reading is inacccurate because he is not load testing. At 2200 rpm you adjust a varible resitor till you get a current reading of 33 amps and check the voltage. The varible resistor creates a voltage drop so Aaron's 15.9 v unloaded could be 14v with the load.
bondo
post Apr 16 2005, 12:55 PM
Post #24
QUOTE (ws91420 @ Apr 16 2005, 11:46 AM)
The reading Aaron is getting is false because he does not have a load on it. An alternator must be load tested for accurate results. I was descriding how a alt works wasn't sure where the change from AC to DC occured in the alt just that it went through the diodes.
It takes alot of current to push an optima over 16v, unless its bad. It shouldn't be able to happen if everything is right. It could also be a short in the harness that's giving the full battery voltage 12v to the field. That COULD make the alt light come on, but I'm not sure. Most FLAPS will test your charging system for free while its in the car.
Joe Bob
post Apr 16 2005, 01:23 PM
Post #25
Because your car is too low and is riding on the bumper stops....
Aaron Cox
post Apr 16 2005, 01:27 PM
Post #26
geoff, the light didnt get any brighter from what i could tell... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
messix
post Apr 16 2005, 01:52 PM
Post #27
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
K.I.S,S
keep it simple.... look for bad grounds... motor to chassis and motor to battery. also dont over look corrosion at the alt. mounts and connections.
it could be a bad battery. low internal resistance will cause high charge voltages. test it with a battery load tester. or charge with a battery charger to full charge 13.5 volts @ 2amps then put as much load on it from head lights, high beams, blowers and with a vom look at the voltage drop. try to calculate amp load, ie; headlights 55 watts = 55/12=4.5amps and then you can calculate voltage drop/ time and amp load will tell battery condition.
messix
post Apr 16 2005, 01:57 PM
Post #28
sorry amend to last post
while doing last test, engine off . not running
pete-stevers
post Apr 16 2005, 01:58 PM
Post #29
saved from fire!
Group: Validating
Aaron my funny-lookin brother, Greg had a similar problem checked every darn thing on the car including replacing the brushes.... he ended up sanding down the contacts to the body......and fixed....not sure if it relates to your electrical poltergiest....it drove him (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) .....so good luck
steve
lapuwali
post Apr 16 2005, 02:50 PM
Post #30
Not another one!
QUOTE (ws91420 @ Apr 16 2005, 10:54 AM)
If the VR is working, and the wiring is good, and the battery isn't internally shorted, the voltage across the battery terminals should never be over 15v at any time. I'm completely lost as to where you're coming up with this "load testing" business. The battery IS a load, and if the car is running there's a non-zero load on the battery, as the ignition and injection systems take up 5-6amps just doing their jobs, even at idle. So, there's always a load when the engine is running.
The alternator just pumps out current until the voltage regulator stops it. As bondo said, it varies the field current to do this, and the field current passes through the brushes. Less current means less output, and the VR operates in a feedback loop, measuring the current coming out to vary the field current and keep it in bounds.
My guess on Aaron's problem is BOTH voltage regulators are bad, even the new one. It's been known to happen.
ws91420
post Apr 16 2005, 03:33 PM
Post #31
The battery is not a load it acts like a capacitor when the car is running. To effectively test any altenator you have to put a load on it. The factory manual states to test an alternator to hook up a VOM, an ammeter, and a variable resistor. Rev the engine to 1400 or 2200 or 6000 rpm. Change varible resistor till you get apporiate amp reading for rpms used. Then measure voltage. 14000 rpm = 10 amp 2200 rpm = 33 amp 6000 rpm = 50 amp This all assuming you still have stock 50 amp alt. Basic electronics you get a drop in voltage after the resistance. If the problem Aaron has described is what I think it is load testing wont do any good either because I tested mine and it did fine at the appropriate rpm but the light was still a problem till I replaced the brushes. This was on my other 914 I was driving till this one was ready and now that alt is on my 76.
BTW the brushes help power the field. the current goes from the outer windings to the diode trio and to the batt post.
Found this about alternators.
Load testing is a standard practice for testing alternators and batteries. Check any service manual of a car that has an alternator.
lapuwali
post Apr 16 2005, 04:36 PM
Post #32
Not another one!
Welby, I know how alternators work. I also understand basic electronics.
Your procedure is quite correct for testing an alternator that's not installed in the car, or is in the car but isn't hooked up to anything. However, when the car is running, no "variable resistor" is required. The battery has internal resistance. So do capacitors, for that matter. Any resistance is a load. From what I read, Aaron was not measuring the output of the alternator by disconnecting it from everything, he was measuring it with it in a running car, which meant the ignition and injection HAS to be getting power from the battery, so it presented a charging load to the alternator. Indeed, it presented the same charging load that is present most of the time when the car is running. If the voltage is higher than 15v under those conditions IT'S TOO HIGH.
Buy a $30 voltmeter and hook it up to your battery terminals and drive around in the car. You'll find the voltage typically stays around 13-14v, assuming your car is operating properly. It never gets above 15v unless something is wrong.
ws91420
post Apr 16 2005, 04:45 PM
Post #33
I am An ASE certified parts specialist (which is more than knowind an alternator from a generator) before you comment on how to test on a car read a manual. The procedure is from the Porsche factory manual so if if they don't know what they are doing then who does. I have worked on cars since I could help my dad who was an ASE certified technician with over 30 yrs experience and numerous awards for training.
plas76targa
post Apr 16 2005, 04:50 PM
Post #34
Aaron -
I may be throwing a curve into your analysis.. but I had a similar problem with my car - high voltage. I replaced the VR, had the alternator out and tested, cleaned all grounds, still high voltage. WTF? Somewhere I had read a post about the relay board. So I borrowed one locally and that fixed the problem. Might be worth a try.
I will note, my gen light never came on. It does work, it would come on at key turn and go off like normal after the car started. With yours coming on as you've described the RB might not be your problem. Anyway just my $.02 - hope you have it solved by WCC
ws91420
post Apr 16 2005, 05:16 PM
Post #35
QUOTE (lapuwali @ Apr 16 2005, 03:50 PM)
That proves my point of the brushes. When it got hot the less current light comes on. Next AM brushes making questionable contact light flickers. The car does not produce a sufficent load on its own to load test an alt. Also you can not test an alt with a bad/shorted battery because that will give a false reading. If you go to your FLAPS and they test your alt on the car thay rev it to 2000 rpm and if you listen you hear the machine click and a countdown starts for 60 sec and at the end it clicks again. The click is a load being applied and taken off. If you put your hand over the machine you will feel the that is generated by the resistor that is used.
Aaron Cox
post Apr 17 2005, 02:10 PM
Post #36
and the final consensus is?
ill drive it around with a VOM meter hooked up to it...
Brad Roberts
post Apr 17 2005, 02:18 PM
Post #37
914 Freak!
Flip a known good relay board into it.
B
Toast
post Apr 17 2005, 02:27 PM
Post #38
And while you're at it, lower the mount for the relay board for your AX career.....ya know...lower center of gravity (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Aaron Cox
post Apr 17 2005, 03:45 PM
Post #39
QUOTE (Brad Roberts @ Apr 17 2005, 01:18 PM)
B
ok. ill have to try that.
i used the VOM's continuity meter... the alt harness makes it to the regulator just fine....
maybe its elsewhere on the relay board.. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
thanks B
Toasty....
real funny.... dont convolute a tech thread (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 1st July 2025 - 02:06 AM
