cal914 |
Member ![]() ![]() Group: Members Posts: 321 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None ![]() |
My speedo won't work unless I give the glass a knock or go over a pot hole on the road , what could be causing this
B |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
My speedo won't work unless I give the glass a knock or go over a pot hole on the road , what could be causing this B are you pushing it (IMG:style_emoticons/default/av-943.gif) cables coming loose or broke JMO MikeC |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,208 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The bits inside are gummed up.
Does the odometer still count up? If it only does when the speedo is working, then it could be a problem in the cable or angle drive or other such. Bug if the odometer goes up and the speedo needle doesn't move, something is messed up inside the speedo housing. A VDO repair shop should be able to fix it. Or you can try taking it apart yourself and cleaning up stuff. --DD |
Lo-Fi Version | Time is now: 30th July 2025 - 11:47 AM |
