Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,192 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() |
Got tired of looking for these some have them listed at $75 and 90, but no Who's interested? I know I need one soon!
Attached image(s) ![]() |
914Next |
Senior Member ![]() ![]() ![]() Group: Members Posts: 596 Joined: 28-July 14 From: Atlanta Member No.: 17,695 Region Association: South East States ![]() |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,581 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() |
Hey Mark,
I know that they needed to be the correct part number CHT for each MY & engine in order to work properly - i.e.: -037 for the `73 2.0, -043 for the `74 2.0 (maybe 75 & 76 GC 2.0 too??), etc.? So will you be making them in the various "flavors" to match to the EFI systems in the different MYs & engines of the 914s, as did Bosch? (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
jim_hoyland |
Goldfish - since 1983 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,495 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() |
Great! Gonna be ok for thT 1.8L L-Jet ?
hndyhrr |
Member ![]() ![]() Group: Members Posts: 362 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest ![]() |
me also, if for 70 1.7
Mikey914 |
Well I have the spec for the 012, so I can make it work. I'm not sure the variations on the others, is it size or resistance? Anyone know for sure?
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,505 Joined: 9-January 03 From: Silly-con Valley, CA Member No.: 121 Region Association: Northern California ![]() |
They're physically the same, the only difference is the resistance/temperature curve. I think Brad Anders has some graphs on his website.
--DD |
Marty Yeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,352 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() |
Mark,
MCMark had an alternative design he worked out for these. It is supposed to be a more modern construction alternative. You may want to contact him regarding it before you dive into production. Marty |
Tom_T |
They're physically the same, the only difference is the resistance/temperature curve. I think Brad Anders has some graphs on his website. --DD IIRC it is those + the reaction time is slower on the -037 with the factory in-line resistor, but the ECU, MPS, etc. are all set up to work together correctly, while mixing components generally leads to running problems. Probably Brad Mayeur or Brad Anders can explain the details better than I! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Mikey914 |
Mark, MCMark had an alternative design he worked out for these. It is supposed to be a more modern construction alternative. You may want to contact him regarding it before you dive into production. Marty I'll check in with him too to see what he's got, thanks, mark |
Dave_Darling |
I was mis-remembering the CHT sensor info. What I found on Brad Anders' site is the following:
Sensor Temp = 39 deg. F (ice bath with thermometer) Temp = 61 deg. F (room temperature) Temp = 210 deg F (boiling water at 1000 feet altitude) 0 280 130 003 6.10 K ohms 2.94 K ohms 199.3 ohms 0 280 130 012 NA 2.85 K ohms 191.2 ohms 0 280 130 017 3.63 K ohms 1.74 K ohms 124.7 ohms Not a chart, but a table. It comes from about 3/4 of the way down this page: http://members.rennlist.com/pbanders/DJetParts.htm The ECU page (http://members.rennlist.com/pbanders/ecu.htm) has charts showing voltage on one specific point inside the ECU versus CHT resistance. That may have been what I was remembering. --DD |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,131 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() |
So are you probing (IMG:style_emoticons/default/sheeplove.gif) the community? (IMG:style_emoticons/default/poke.gif)
I'll probably need a spare for the white car's 1.7L (1.9L) |
Mikey914 |
Well looks like there is enough commonality that they may be interchangeable, but not identical based on this -
Available new. The ...012 sensor is in short supply. Either sensor should work OK. I'm looking at doing these again because I need them. Offering up the GB to those that are interested, but may raise the price to $75 after the GB if there's not much interest on these. I did ping McMark on the phone today, but will follow up if he has a better answer. I may have located suitable materials for the build but can't check til Monday. I don't have much of a choice as I do need one, so I will be working on a solution one way or another. Just really surprised that there's not much interest. |
McMark |
I'm a 914 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,921 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: North East States ![]() |
I forwarded my info to Mark so he can proceed with this. (IMG:style_emoticons/default/thumb3d.gif)
If you're car doesn't run well until it warms up, you might have a CHT issue. Any stock FI car that's working correctly should run as well cold, as it does warm. |
Mikey914 |
SO,
As noted we will be making the Original Customs version of these. They will be 3-4 weeks out. I Like what Mark had going with these and we can make these available again. The key here is we need some quantity to get the price down, so hopefully there is enough demand to make these pencil out. Right now the only sources that "say" they have them are at least $80. The discussion I had with Mark was that most people don't realized these have failed as think as it's an old car it will run a little rough until it warms up. They just live with it. We will be doing a diagnostic video (once my car is back together to show you the effect of the failed one I have and the improvement. There is a good possibility that a few could benefit from having these and don't realize it. SO if you want in on the GB price you will need to bump the thread to get the code when ready. Given the costs these will be about $60 after the GB SO whos' in? |
euro911 |
Yep, need at least one here (IMG:style_emoticons/default/smile.gif)
enikolayev |
Newbie ![]() Group: Members Posts: 45 Joined: 18-November 07 From: Williamsburg Member No.: 8,349 Region Association: MidAtlantic Region ![]() |
Count me in for one as well.
Philip W. |
Dr. Phil ![]() ![]() ![]() ![]() Group: Members Posts: 2,754 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() |
I will take 2!
Java2570 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 642 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest ![]() |
Put me down for one!
Mueller |
Back in the game...trying to keep this one stockish! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,992 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() |
I'm in for one, any discount if I machine my own housing? (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 23rd April 2018 - 04:20 PM |
