| Kansas 914 |
Sep 17 2016, 12:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,008 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
I am just curious what the collective brain trust thinks about old cracked dashpads for cores.
I know if couple sources now for new dashpads and none of them require a core. Is it time for me to trash my cores? |
| 76-914 |
Sep 17 2016, 02:03 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
| ConeDodger |
Sep 17 2016, 10:11 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,652 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
I am just curious what the collective brain trust thinks about old cracked dashpads for cores. I know if couple sources now for new dashpads and none of them require a core. Is it time for me to trash my cores? I think so. Stoddards and 914Rubber both are completely new parts. 914Rubber at least is as good or better than the original. No need to keep your old ones except perhaps for the plastic fastening nuts? |
| Mikey914 |
Sep 18 2016, 12:46 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
They may have some value it you want to recover one in leather. The main problem is the droop. If the inst cluster has a sag you will probably want to toss as you can't get it out.
| SixerJ |
Sep 19 2016, 03:26 PM
Member ![]() ![]() Group: Members Posts: 451 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
They may have some value it you want to recover one in leather. The main problem is the droop. If the inst cluster has a sag you will probably want to toss as you can't get it out. What about the late verses early pads? Might be worth hanging onto early good cores (if you can call them that). Until you decide to make the early one (IMG:style_emoticons/default/poke.gif) |
| Chris914n6 |
Sep 20 2016, 12:01 AM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,565 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Pre-RRC I would have offered to take them home with me. At some point in time I will have a vacuum machine built big enough to accommodate re-skinning dash pads in different vinyls.
| Mikey914 |
Sep 20 2016, 12:38 AM
The problem is the correct vinyl is not available. mainly because the process in which these were made the original vinyl is not thick enough to pull over the part.
It will not hide any sins, without the extra padding just dashes uses, and then you get a part that has to be stripped and prepped. It's a lot of messy work and the product you get is not correct (fatter). This is just what my research has come up with, but hey, maybe you'll have more luck with it. |
| 914werke |
Oct 11 2016, 04:57 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,796 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
so.....short of preferring the leather / exposed stitching look, Zero value?
Ive got to get rid of some stuff (IMG:style_emoticons/default/wacko.gif) |
| Kansas 914 |
Oct 11 2016, 05:16 PM
so.....short of preferring the leather / exposed stitching look, Zero value? Ive got to get rid of some stuff (IMG:style_emoticons/default/wacko.gif) I have 4 in my stash...... |
| Chris914n6 |
Oct 11 2016, 06:28 PM
I didn't say anything about using the correct German haircell. There is a company in town that does old Mustang dashes that told my upholstery shop owner who told me how to use standard vinyls. He also has American haircell in stock.
Watch the JustDashes video, it's involved, and it told the whole process (IMG:style_emoticons/default/idea.gif) Standard technique for 70's dashes. As far as cores, it would be nice to have a few on hand to work with, but I'm far enough away from actually doing it that it's not something I would want to put much money into. The IR heater I bought at the neighbors garage sale might not even work. If you want to, pm me shipping costs to 89121. The problem is the correct vinyl is not available. mainly because the process in which these were made the original vinyl is not thick enough to pull over the part. It will not hide any sins, without the extra padding just dashes uses, and then you get a part that has to be stripped and prepped. It's a lot of messy work and the product you get is not correct (fatter). This is just what my research has come up with, but hey, maybe you'll have more luck with it. |
| EdwardBlume |
Oct 11 2016, 08:42 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I chucked mine... but then again, I ripped it out. (IMG:style_emoticons/default/evilgrin.gif)
Lo-Fi Version | Time is now: 15th November 2026 - 05:28 AM |
