Has anyone ever tried this???, Rust Converter |
stevenhaas |
Apr 16 2005, 06:22 PM
Member Group: Members Posts: 55 Joined: 9-April 05 From: New Jersey Member No.: 3,907 |
Hey! Has anyone tried this product??? I have been looking around for a good sealer and what not and stumbled on this....
Rust Converter |
Lou W |
Apr 16 2005, 07:07 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
No, I'm using this: Rust Bullet
I'm brushing on Metal Prep first, then applying Rust Bullet. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
firstknight13 |
Apr 16 2005, 07:34 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
i used it and it's NOT what i would recomend!! POR 15
scotty b |
Apr 17 2005, 07:06 AM
There was a thread on this a couple of weeks ago and I and a few others have had BAD experience with POR-15. My experience was on a customers CJ-8 that he put it on the frame. I had to straighten the front of the frame after he brought it over and the POR cracked and peeled off like sunburnd skin. I recall someone else in that trhtead saying he knew of several British car guys who had similar experiences. I use Right Stuff rust converter and Eastwoods Rust encapsulator over top, and have been VERY pleased with both. |
Katmanken |
Apr 17 2005, 09:35 AM
Best way to test if the "rust miracle cure" paint really works is to take a piece of sheetmetal, cut off a strip, finish half the length per the directions and allow the paint to cure.
Mix up salt and water in a container and place the painted end (and some of the unpainted end) of the strip into the salt solution and leave it for a while- say several weeks or a month. Pull it out and you have an indicator of how well it works. Ideally, we, as a group of rusty car owners should get together and test a whole bunch of samples with different paints in a container of salty water and have one person report on the results. Then we would know what works. A British magazine did this and also scored the treatment with a nail. Oh, yeah, instrad of the container, they put the samples outside and sprayed them with salty water every week for a year. Some of those cavity waxes were darned impressive as they oozed to seal the scratch and even had rust inhibitors that worked some distance away from the wax application. Some of the paints weren't so good. Ken |
Type 4 |
Apr 17 2005, 09:52 AM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Hammerite is the best.
Waxoly is a very good sealant for inner areas. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:11 AM |
