1.8L Motor refresh, Which piston size is best??? |
catsltd |
Sep 19 2016, 08:22 AM
Member Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
I am going to install new pistons/cylinders,and refresh the heads.
Quick question. I am keeping the fuel injection on my 1.8L. So should I keep the stock 93 MM cylinders,or go to a 96MM aluminum for added cooling. If I go to the 96MM will I run into drive ability problems??. http://aapistons.com/products/vw-porsche-9...der-kit-914-bus. My compression went from 90 PSI hot motor throttle open to 150 PSI with a few drops of oil. Can I do this cylinders myself???. Thanks for any advice or suggestions. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:37 AM |
