Switching to Inline Fuel Pump on D-Jet |
Groosh |
Sep 19 2016, 08:38 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
I have a Bosch inline fuel pump picked up somewhere along the line. I'd like to use it to replace the OEM triple outlet pump. The Bosch specs at 72 psi. Will the regulator handle the pressure since it's suppose to be about 29 psi?
Also, do I simpy connect the return line back to the firewall plastic line to tank that used to go into the OEM triple "R" line? Thanks. |
914_teener |
Sep 19 2016, 09:05 PM
914 Guru Group: Members Posts: 5,200 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Yes to both.
Groosh |
Sep 19 2016, 09:06 PM
Lo-Fi Version | Time is now: 28th May 2024 - 01:43 PM |
