Transaxel, hmmm.. |
Transaxel, hmmm.. |
914werke |
Apr 17 2005, 12:50 AM
"I got blisters on me fingers" Group: Members Posts: 10,057 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Short of tearing into you trans how would you tell if a it has a limited slip diff installed?
Joe Bob |
Apr 17 2005, 01:00 AM
Jack up the rear, turn the wheels...both turn the same way...ya got some sort of locked rear end.
messix |
Apr 17 2005, 01:13 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
transaxel.......isnt that the little fella from guns n roses
lapuwali |
Apr 17 2005, 01:14 AM
Well, the most reliable way is to park the car with one wheel on ice and the other on asphalt. If you can drive away, you have an LSD. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
If you have both wheels off the ground, then spinning one by hand will cause the other to spin the opposite way with an open diff. With a clutch type, both wheels will spin the same direction (at least if you spin one wheel fast enough). However, with a Quaife-type LSD, it will behave like an open diff if one (or both) wheels are off the ground, so that's not a 100% reliable method. I've heard that you can't turn both wheels (or the halfshafts) in the same direction at the same time by hand with a Quaife, but I've never tried it. |
ArtechnikA |
Apr 17 2005, 05:56 AM
yeah - now that he's wearing dresses... there should be a Type number on the transmission that will tell you what it was originally, anyway. IIRC, 'A' is open diff, 'B' was the factory ZF clutchpack LSD. if a ZF diff hasn't been serviced in 30 years you can probably count on the clutches being toast, reverting it to open function... |
914werke |
Apr 17 2005, 07:53 AM
What if in air you turn either wheel , the other wheel is unaffected?
ClayPerrine |
Apr 17 2005, 08:10 AM
Life's been good to me so far..... Group: Admin Posts: 15,456 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I know for a fact that if you turn one wheel on a guard diff, the other will turn the same way. It acts like a spool until something overcomes the drag in the gears, then it will spin different.
BTDT!! |
ArtechnikA |
Apr 17 2005, 08:14 AM
transmission in neutral, parking brake off and not dragging?
could be time to find the type number - i think it's near the serial number or on the ventral rib. this has been discussed before - check the archives for LSD discussions. |
Apr 17 2005, 02:16 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Then you need to put the transmission into gear. --DD |
Red-Beard |
Apr 17 2005, 03:29 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
no Dave.
I'm guessing you have a standard diff with lots of drag in the brakes....or something... |
Apr 18 2005, 03:57 PM
Nope. The rotation has to go somewhere. If you turn the one rear wheel, and the other does not turn at all, the rotation is either going to the input shaft (it is spinning; it won't turn over an engine that easily unless the plugs are out) or it is indeed going to the opposite output flange, but the CV joint is broken.
Occam's Razor (suspect the simplest things first) tells us that you forgot to put the transmission into gear. If it really is in gear, then you need to look at the fan or the flywheel or the distributor when you turn the one wheel and the other doesn't turn. If that is not turning, then you look at the CV joints. If they are hooked up and in good shape, then you have detonated the transmission itself. --DD |
Red-Beard |
Apr 19 2005, 08:07 PM
Dave, I have a differential out of a transmission. It is not in gear and behaves that way.
Apr 20 2005, 01:32 PM
What way does it behave? I'm having difficulty picturing how that applies to this argument...
--DD |
Lo-Fi Version | Time is now: 13th May 2024 - 08:38 AM |
