6 cyl case, trying to ID |
cwpeden |
Sep 21 2016, 01:54 PM
JmuRiz |
Sep 21 2016, 02:02 PM
914 Guru Group: Members Posts: 5,422 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
'79 SC case, based on the engine number, right?
Looks like Japan market, I think. Just guessing that's what the (J) in the engine serial number decoder means. |
cwpeden |
Sep 21 2016, 02:25 PM
sixaddict |
Sep 21 2016, 02:29 PM
Senior Member Group: Members Posts: 795 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
I have recently been told factory warranty replacement engines have stars to designate that being the case ... I see 2 stars.... and the 640 # is six case as you know
GL on quest |
JmuRiz |
Sep 21 2016, 02:38 PM
'79 SC case, based on the engine number, right? Looks like Japan market, I think. Just guessing that's what the (J) in the engine serial number decoder means. Where do you see a J? http://members.rennlist.com/emcon5/eng78_83.jpg |
jcd914 |
Sep 21 2016, 03:49 PM
SC case is aluminum and that case looks like magnesium.
Vysoc |
Sep 21 2016, 03:55 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Here is what I see the *6400653* top engine case is a 1970 914-6 Case.
The bottom case is 6190446 this shows to be a 1969 911T Coupe case. I also do not see where you are finding the "J" in the number? (IMG:style_emoticons/default/confused24.gif) Vysoc (IMG:style_emoticons/default/flag.gif) |
cwpeden |
Sep 21 2016, 05:00 PM
If you look at the link in JmuRiz's post it shows all the engine numbers based on the market they were made for?
I don't think the 619**** is genuine. I don't plan on using it as its just a case but if it was a /6 case it would make a good conversation piece. |
bretth |
Sep 21 2016, 07:44 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Here is a pic of the number on my 69 911T case for comparison. Looks very similar to yours. But i do not have another number near the breather on top.
Attached thumbnail(s) |
bretth |
Sep 21 2016, 07:52 PM
On second look I see that the font size for your 911T number is huge compared to the one on my case.
Brett |
infraredcalvin |
Sep 21 2016, 09:12 PM
Distracted Member Group: Members Posts: 1,504 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Do the case pairing numbers match?
cwpeden |
Sep 21 2016, 10:55 PM
No.
914Sixer |
Sep 22 2016, 06:04 AM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If the half numbers don't match the answer is some one made the case out of two halfs.
Mark Henry |
Sep 22 2016, 07:15 AM
sixnotfour |
Sep 22 2016, 08:13 AM
914 Wizard Group: Members Posts: 10,406 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the stamped numbers on the top do not match ???
cwpeden |
Sep 22 2016, 08:44 AM
oh I see! I'll check those.
Mark Henry |
Sep 22 2016, 08:57 AM
Those are the numbers I'm talking about, different places but T1 and 4, plus the /6 has them.
If they don't match they are the halves from two different engine cases. |
sixnotfour |
Sep 22 2016, 09:46 AM
Those are the numbers I'm talking about, different places but T1 and 4, plus the /6 has them. If they don't match they are the halves from two different engine cases. (IMG:style_emoticons/default/agree.gif) the side numbers cast into the lower half of the cases is prob..3R and 2R most likely its a -6 engine someone thought they should stamp the ex 911 engine number into it. |
cwpeden |
Sep 22 2016, 11:12 AM
Case halves are same number stamped in stud boss.
Part numbers are 901.101.102.2R and 3R. Interesting, anyone looking for the original case for their 914-6? s/n 6400653 |
rgalla9146 |
Sep 22 2016, 11:28 AM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Look at the horizontal number near the flywheel, next to the oil pressure switch you'll find 901/ 38
If so, the engine IS a 914 6 The numbers on the vertical fan support are bogus. This is easily verified. If you don't see a type number ( in this format; 911/38.... is a 911 RS engine) on the right engine case under the fan saddle it is not a 911 engine. Someone wanted this to appear to be 911 engine. They probably thought it was a replacement block because it had no numbers there. |
Lo-Fi Version | Time is now: 19th April 2024 - 11:12 PM |
