6 cyl case, trying to ID |
cwpeden |
Sep 21 2016, 01:54 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
rgalla9146 |
Sep 22 2016, 11:28 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Look at the horizontal number near the flywheel, next to the oil pressure switch you'll find 901/ 38
If so, the engine IS a 914 6 The numbers on the vertical fan support are bogus. This is easily verified. If you don't see a type number ( in this format; 911/38.... is a 911 RS engine) on the right engine case under the fan saddle it is not a 911 engine. Someone wanted this to appear to be 911 engine. They probably thought it was a replacement block because it had no numbers there. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:24 PM |
