BlazeCut Installation, What I learned.... |
oakdalecurtis |
Sep 24 2016, 01:33 AM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I purchased the 6 foot BlazeCut Fire Suppression System. This length only requires one length down one side of the lid, one curve, and one length back the other side of the lid. I also found that the stiff tubing does not like to bend into a tight enough arc to fit into the confines of the engine lid. The tube kinked at the center of the curve, but I don't think it damaged it. I bought an electrical gray pipe curve, 3/4" ID, split it with my band saw, and zip tied and taped it around the BlazeCut tubing at the center of the arc where the tubing wanted to kink. This supported and held the tubing, keeping the tubing in the required arc while preventing it from kinking. I also found that plastic zip ties were not strong enough to hold the tubing in position under the engine lid. The stiff BlazeCut tubing does not like to bend or go where you want it to very easily. As you can see, I removed my rain tray a while ago since I never take the car out in bad weather and the engine runs cooler without it.
I fastened the tubing to the underside of the engine lid using metal pipe claps, 3/4 ID, and short self tapping metal screws into the lid supports. I wrapped the BlazeCut in heavy plumbers tape wherever it came in contact with the metal lid. I also cut thin strips of black tape and put them on the top side of the BlazeCut tube so you could not easily see the white tubing through the engine grill from the outside. If you look on the left side of my engine lid, you can also see a steel braided cable I added a while back so I don't have to hold on to the engine lid when I open it. Without the cable, if you popped the engine lid and didn't hold it, it would fly open and put a lot of bending force on the hinges, which I have already rewelded once. Now the cable catches it before it works on the hinges. BTW, if you have a weak opening engine cover, here's a link to an easy and simple fix that lets you put more pop in the opening, especially with the extra weight of the BlazeCut under the lid. My lids pops open fully now, even with the tubing under it. http://www.914world.com/bbs2/index.php?sho...=290514&hl= I hope I never have to find out how well the BlazeCut tubing works! |
FlacaProductions |
Jul 9 2020, 11:07 AM
Senior Member Group: Members Posts: 1,588 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@BeatNavy - given the recent couple of engine fires that have been documented here, I thought I'd dig this thread back up - any luck on an install WITH the rain tray over the years?
BeatNavy |
Jul 9 2020, 01:18 PM
@BeatNavy - given the recent couple of engine fires that have been documented here, I thought I'd dig this thread back up - any luck on an install WITH the rain tray over the years? Hey Brian - as Ben noted above, I ended up giving mine to him so he could install. I still wanted to keep the rain tray and didn't want to try to make it fit with that. Hopefully I won't come to regret that in a big way, and hopefully Ben won't need it! |
mb911 |
Jul 9 2020, 01:32 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
@BeatNavy - given the recent couple of engine fires that have been documented here, I thought I'd dig this thread back up - any luck on an install WITH the rain tray over the years? Hey Brian - as Ben noted above, I ended up giving mine to him so he could install. I still wanted to keep the rain tray and didn't want to try to make it fit with that. Hopefully I won't come to regret that in a big way, and hopefully Ben won't need it! I agree. 2020 has been an overall awful year in many ways.. I don't want to need it. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 PM |
