BlazeCut Installation, What I learned.... |
djway |
Jul 9 2020, 11:36 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
https://www.amazon.com/dp/B077LVMGJ4/?colii...lv_ov_lig_dp_it
I just found these on Amazon. You can put in 4 for the price of a blaze cut. Purple too. I have a blaze cut on my 914 with rain tray and it does not fit well but its in there. |
jd74914 |
Jul 10 2020, 06:26 AM
https://www.amazon.com/dp/B077LVMGJ4/?colii...lv_ov_lig_dp_it I just found these on Amazon. You can put in 4 for the price of a blaze cut. Purple too. I have a blaze cut on my 914 with rain tray and it does not fit well but its in there. Ehhh...found in the questions section: Question: Does this have any certifications with any fire agency? I see the description lists all types of fires, but I don't see anything about testing. Answer:We have several certifications for the fireball, one is RoHS2 DIRECTIVE 2011/65/EU another is the MSDS safety test and the CE test report plus we have gone through the China National Quality Supervision and Testing For Fire Fighting Products. Just FYI for those who don't know: RoHS is a rule about hazardous waste in electronics, MSDS is a Material Safety Data Sheet (tells you the exposure risks), CE is a self-certifying report that says the manufacturer tested it, and in general only applies to electronics. And I'm not going to comment on the China National Quality thing... Be careful if you want to try that product out. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/shades.gif) |
mlindner |
Jul 10 2020, 07:38 AM
Senior Member Group: Members Posts: 1,515 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I wonder if you could put two shorter lengths instead of the long looped style. Mark
FlacaProductions |
Jul 10 2020, 10:01 AM
Senior Member Group: Members Posts: 1,569 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
oakdalecurtis |
Jul 10 2020, 10:31 AM
Oakdalecurtis Group: Members Posts: 1,324 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Olympic 914 |
Jul 10 2020, 11:29 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
What about running it around the perimeter of the engine bay instead of putting it on the lid? Maybe fit a longer one in there. I don't know what sizes are available.
oakdalecurtis |
Jul 10 2020, 11:42 AM
What about running it around the perimeter of the engine bay instead of putting it on the lid? Maybe fit a longer one in there. I don't know what sizes are available. hey Olympic, Regarding engine bay perimeter installation of the BlazeCut tube, I would speculate that it would probably still work in a fire, but might take longer to activate, as it is the direct flame that melts the hole in the plastic tube and allows gas release. If the tubing is on the perimeter alongside the fire and not above the flames, it might take longer to reach melting temperature and activate..... |
mlindner |
Jul 10 2020, 11:47 AM
I wonder if you could put two shorter lengths instead of the long looped style. Mark Hey mlind, even the shortest BlazeCut is 44 inches long, obviously too long to use straight only. Highly pressurized, cannot be cut or shortened... Just found the shortest is 100cm/39 inches, that would work great with two straight ones behind the engine grill. Mark |
FlacaProductions |
Jul 10 2020, 12:00 PM
I see the shortest being 44" but i can't go out and measure where that would work...
https://www.blazecutusa.com/products/t100e |
Jamie |
Jul 10 2020, 12:35 PM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
https://www.amazon.com/dp/B077LVMGJ4/?colii...lv_ov_lig_dp_it I just found these on Amazon. You can put in 4 for the price of a blaze cut. Purple too. I have a blaze cut on my 914 with rain tray and it does not fit well but its in there. Ehhh...found in the questions section: Question: Does this have any certifications with any fire agency? I see the description lists all types of fires, but I don't see anything about testing. Answer:We have several certifications for the fireball, one is RoHS2 DIRECTIVE 2011/65/EU another is the MSDS safety test and the CE test report plus we have gone through the China National Quality Supervision and Testing For Fire Fighting Products. Just FYI for those who don't know: RoHS is a rule about hazardous waste in electronics, MSDS is a Material Safety Data Sheet (tells you the exposure risks), CE is a self-certifying report that says the manufacturer tested it, and in general only applies to electronics. And I'm not going to comment on the China National Quality thing... Be careful if you want to try that product out. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/shades.gif) The posted specs say should not to be exposed to water, so not a good idea to be mounted in the exposed engine compartment of a 914. |
mlindner |
Jul 10 2020, 01:39 PM
I see the shortest being 44" but i can't go out and measure where that would work... https://www.blazecutusa.com/products/t100e The T100 E has a tube length of 100 cm, 39 inches, easily fit two straight tube under 914 engine lid. |
FlacaProductions |
Jul 11 2020, 09:21 AM
@mlindner - I think we're looking at the same product here but getting different specs.
I don't see 39 inches listed anywhere...it does say: "44" unit length" I'm wondering if the tube is 100cm/39 inches but the overall unit is 44" when including the fittings on each end. https://www.blazecutusa.com/products/t100e |
mlindner |
Jul 11 2020, 09:43 AM
So if with the metal ends it 44.....still works since the engine lid is 46 inches wide. Mark
FlacaProductions |
Jul 11 2020, 01:31 PM
Now to figure out a way to secure/attach....
mlindner |
Jul 11 2020, 02:30 PM
Come-on FlacaP.....we all fabricate, that is not an issue. Best, Mark
FlacaProductions |
Jul 11 2020, 04:16 PM
Someone else has to lead the way on this - i'm 2100 miles away from my 914 and i won't be around it anytime soon. sad face.
ClayPerrine |
Jul 12 2020, 07:20 AM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Betty and I are seriously considering this for our 914s, but we have some reservations.....
How hot does the engine compartment get? Is it hot enough on a hot Texas summer day to activate it? What happens if you have two installed, you have a fire, and only one of them discharges? The other one is immediately suspect, and would have to be disposed of. But how do you get rid of it? The Blazecut units contain HFC227ea. In the computer world, this is known as "FM200". It is a gas that suffocates a fire, so no powder residue. But I know from safety briefings on computer room operations that you can't be in the room when the FM200 is discharged. It will kill you via suffocation. What happens if you are in the car when it goes off? Will it get in the car? If so, how much does it take to suffocate you? And what about all of you that have cut an access panel in the firewall? Does it seal tight enough to keep it out? Clay |
ClayPerrine |
Jul 12 2020, 08:11 AM
Doing some shopping online and found this:
FireSlayer Automatic Tube Style Fire Extinguisher They also have this disclaimer on their page: "At this time the FireSlayer is not an FM, UL or SFI Approved fire extinguishment device." |
Coondog |
Jul 12 2020, 08:20 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Let’s see if I can answer some of the points Clay brought up.
I live in the desert and my concern is the continued heat that the tubes would be exposed to. In time this could cause the tubing to weaken. If your running two tubes and one activates but does not completely put out the fire then the fire would have to get large enough to activate the other tube. If the other tube didn’t activate during a fire then I agree it’s highly compromised. You would have a greater exposure to the toxic smoke from your car on fire then this system depleting the oxygen to the point it would cause suffocation. These systems just temporary remove the oxygen which of course puts out a fire but does not keep the gasoline from emitting fumes or does it get to any fire that’s underneath your tins. Unless you pay extra for the system with the pressure gauge then you would never know that it’s holding its charge. My gut feeling is you still need to carry a 10 lb.Purple K Fire Extinguisher as a back up. |
ClayPerrine |
Jul 12 2020, 08:29 AM
My gut feeling is you still need to carry a 10 lb.Purple K Fire Extinguisher as a back up. (IMG:style_emoticons/default/agree.gif) We have extinguishers mounted in all of our 914s. They get checked and replaced on a regular schedule. We are not getting rid of them for any reason. |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:53 PM |
