Need help pronto...front trunk stuck closed. |
Cuda911 |
Sep 24 2016, 08:56 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Hey, so I' up here in Lake Arrowhead, and when I pull the handle for the front trunk cable it isn't releasing the latch. Any suggestions? Thanks in advance.
earossi |
Sep 25 2016, 11:21 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
If you pull the bumper off the car, there will be a hole about !/2" diameter through which you should see the front trunk latch lever. I learned about this from another teener on this forum. So, his car and mine have the hole. Your's should as well. Once you have found the hole, you will use the hole as a fulcrum with a screw driver to move the lever sideways to open the latch.
If you want to do away with the latch, you may want to look at hood pins that lock the hood down in the front corners with fasteners that are external. A lot of guys install them for a number of reasons. As I recall, pulling the bumper off the car involves 2 or 4 bolts that you access from the front wheel wells. Google the procedure to be certain. But, my memory tells me that it took me about 20 minutes to get the bumper off. And, once off, access to the latch had the trunk open in about 30 seconds. Good luck! Regarding the vapor lock, you might want to consider relocating the fuel pump to the front trunk. That seems to solve the issue for most folks. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:00 AM |
