Need help pronto...front trunk stuck closed. |
Cuda911 |
Sep 24 2016, 08:56 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Hey, so I' up here in Lake Arrowhead, and when I pull the handle for the front trunk cable it isn't releasing the latch. Any suggestions? Thanks in advance.
Dave_Darling |
Sep 25 2016, 11:26 PM
For the front trunk: There should be a small hole in the front metal panel that is covered by the bumper. You stick a screwdriver in that and push to one side or the other to release the latch.
If you have access to an owner's manual, the process is detailed in there. For the engine lid: Probably the L-shaped metal brackets on the firewall that hold the lid are failing. They crack at the angle of the L and droop, moving the lid out of alignment. You may be able to open the lid by having someone pull on the knob while someone else pushes the rear edge of the lid forward. --DD |
Cuda911 |
Sep 26 2016, 12:04 AM
Thanks all. My front latch seems to be working fine now. I crammed a lot of luggage in there before the trip, and I think it was the upward force of the luggage preventing the latch from opening.
I'll take a look at the engine cover lid later this week and see what's up with that. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:33 PM |
