Led third brake light, Hidden led third brake light |
JP3 |
Sep 24 2016, 07:36 PM
Jerry Group: Members Posts: 61 Joined: 6-August 15 From: New Lenox, IL Member No.: 19,035 Region Association: None |
JustinMeier |
Sep 24 2016, 07:56 PM
Member Group: Members Posts: 244 Joined: 3-August 16 From: Scottsdale Member No.: 20,258 Region Association: None |
ThinAir and his son both have them.. They looked pretty good when I was following them.
Toast |
Sep 24 2016, 08:17 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Let us know how those hold up where you install them in the engine compartment. I have some that I wanted to install. I was thinking somewhere inside near the rear window.
Would you mind posting a picture of what the install looks like in the daytime? |
JP3 |
Sep 24 2016, 09:07 PM
whitetwinturbo |
Sep 24 2016, 09:48 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
.............that's so fire-breathing engine! Where's the build thread?
(IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif) |
euro911 |
Sep 24 2016, 10:18 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Looks good (IMG:style_emoticons/default/aktion035.gif)
I currently have an '86 Corvette 'vert' 3rd. brake light bolted down in front of the engine lid grille. It's better than not having anything, but still want to install an LED strip in the trim piece above the rear window. (IMG:http://www.914world.com/bbs2/uploads/post-7300-1359019595.jpg) |
mgp4591 |
Sep 24 2016, 10:21 PM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Ernie and Mike have the 3rd brake light assemblies from Chevy and GMC SUVs - easy to pull in the wrecking yards and cheep. They have them bolted to the engine cover whereas Strat has his bolted to the underside of his targa bar which puts it much higher and right in your following drivers face... thinking of doing that myself. (IMG:style_emoticons/default/idea.gif)
RickS |
Sep 24 2016, 10:42 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
porschetub |
Sep 24 2016, 11:00 PM
Mine but in the roof ,works great,one lamp wasn't working cause it was loose in the holder easy fix. (IMG:style_emoticons/default/smile.gif)
keely444 |
Sep 24 2016, 11:23 PM
Member Group: Members Posts: 103 Joined: 4-May 15 From: santa cruz Member No.: 18,702 Region Association: None |
THIS IS MY SET UP.
porschetub |
Sep 25 2016, 12:22 AM
Are you talking about your Large Extended Device from the back of your car or the highstop (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) ,IMO very cool (IMG:style_emoticons/default/shades.gif) .
Elliot Cannon |
Sep 25 2016, 10:24 AM
Mine are mounted in the engine grill as well. They have been there about 4 years now.
N_Jay |
Sep 25 2016, 11:07 AM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
Definitely doing this when I get it back on the road.
Also going to get a module that flashes and retriggers with g-force so people really know when you are slowing. |
pvollma |
Sep 25 2016, 05:40 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
Not sure if anyone has tried this before but I added a third brake light using the cheap led light strips from auto zone. I tucked them under the engine lid grating. Mine already had the center reflector strip, so I used that as the mounting location for two LED strips: You do have to grind off the reflective backing before mounting the LEDs. |
euro911 |
Sep 25 2016, 08:29 PM
Don't take this the wrong way ... it looks nice and does add some bright RED to the tail end, but it's still at the same low elevation as the stock taillights.
I thought the whole idea was to install something up higher for better visibility - to catch the attention of those SUV-driving, texting, soccer-moms? (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/unsure.gif) |
Toast |
Sep 25 2016, 09:36 PM
Spoke |
Sep 26 2016, 11:04 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I am not sure how they will hold up with the heat from the engine. Nice setup. I don't think heat will be an issue. LEDs like I use have a high operating temp of 100C (212F). Some other surface mount LEDs have a high operating temp of > 300F. While running, the grill and LEDs should be relatively cool as it sucks in ambient temp air. |
Mikey914 |
Sep 26 2016, 11:17 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Had a discussion at Octeenerfest with Clay, a new easy solution is in the wind.
pvollma |
Sep 26 2016, 12:26 PM
Don't take this the wrong way ... it looks nice and does add some bright RED to the tail end, but it's still at the same low elevation as the stock taillights. I thought the whole idea was to install something up higher for better visibility - to catch the attention of those SUV-driving, texting, soccer-moms? (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/unsure.gif) It's better than nothing, it was an easy installation (already had the reflector, and the brake wiring is right there), requires no additional changes or holes drilled and, being in an unexpected location and shape, it does catch your attention. On our 914s, "higher up" is certainly a relative term! If your "SUV-driving, texting, soccer-mom" is so close that she can't see the normal brake lights, I would suggest a crash is imminent and unavoidable, no matter where the third brake light is located. |
bandjoey |
Sep 26 2016, 01:06 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Used the glue on led strips on the roll bar chrome for about 3 years. Wiring inder the chrome. 24" of lights works great.
Not the best pic but you can see the LEDs here. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd April 2024 - 04:28 AM |
