Warped Engine Lid?, Need Some Help |
turnaround89 |
Sep 25 2016, 01:36 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I think my engine lid may be warped.
I am working on fitting my fiberglass rear decklid to the car and wanted to align the decklid to the engine lid. The previous owner must have broken the engine lid brackets as the welds on them looked awful. I cut those out with the plan to purchase new brackets and weld them in properly. In doing so I began lining everything up and found the problem in the picture below. In the picture I am mocking up the fitment of the engine lid. Holding the engine lid so that the passenger side vent grill matches up perfectly I found that the drivers side is very low at the back side. So, obviously if you match up the driver side with the side vent grill, the passenger side is too high. I did remove the torsion bars on the engine lid so I could move the hinges more easily when the time comes to weld the bracket in. Has anyone else ever had this problem? (IMG:http://www.914world.com/bbs2/uploads_offsite/imgur.com-9067-1474832175.1.jpg) |
Mikey914 |
Sep 25 2016, 02:10 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep been there. Engine deck lid mount placement is everything. Doubtful the deck lid is warped that much.
turnaround89 |
Sep 25 2016, 02:45 PM
So if I put the mounts back on, will the mounts be able to hold the lid to fit properly? Right now it seems like the engine lid is so far off with me just holding it.
turnaround89 |
Sep 25 2016, 03:22 PM
Not sure if this helps, but here is the engine lid on the rear deck lid. One front corner touches the other does not.
Pretty sure this is not correct (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1474838546.1.jpg) |
Mikey914 |
Sep 25 2016, 03:29 PM
Post some pics of the mounts on the car.
It's also possible the U attachments on the lid have been bent some. I've seen one that was adjusted for a mount that was pulling down and away, and when we fixed it had to bend back. Maybe that's what's going on here? |
turnaround89 |
Sep 25 2016, 03:40 PM
The mounts have been cut off the car already. I am planning on ordering the new ones this week.
ndfrigi |
Sep 25 2016, 05:57 PM
Advanced Member Group: Members Posts: 2,926 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Looks like the engine lid is deformed and not just the mounting bracket.
turnaround89 |
Sep 25 2016, 06:30 PM
Thats what I was thinking. I pulled the engine hood latch pin so that I could lay the lid on a flat surface without the pin propping up one side. So the picture of the engine lid shows that it was somehow damaged(dropped, jumped on, etc)
Guess I'll be purchasing a GT engine lid sooner than expected. |
ndfrigi |
Sep 25 2016, 06:57 PM
Thats what I was thinking. I pulled the engine hood latch pin so that I could lay the lid on a flat surface without the pin propping up one side. So the picture of the engine lid shows that it was somehow damaged(dropped, jumped on, etc) Guess I'll be purchasing a GT engine lid sooner than expected. I have a spare lid. But if I sell it maybe for $100 plus shipping. But I recommend GT lid that Sergio makes (member here: PCA7GGR) and just a few more dollars. |
turnaround89 |
Sep 25 2016, 07:20 PM
I greatly appreciate the offer ndfrigi, but since I'm doing an Subaru conversion id like the GT lid for the intercooler.
I just sent a PM to Sergio. Awaiting a reply! |
Lo-Fi Version | Time is now: 18th April 2024 - 07:24 AM |
