Relay board fuse change, want to downsize |
porschetub |
Sep 25 2016, 03:29 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have looped heater blower fan wiring to use for oil pressure circuit,want to downsize fuse from 25amp to just run a carter rotary LP carb pump,can't find the specs for my pump so don't know current draw,question is 10 or 15amp???
Thanks and (IMG:style_emoticons/default/beer.gif) |
porschetub |
Sep 25 2016, 03:54 PM
Finally found specs on Summit website...got a surprise as it only draws 4.5 amp,think a 5 amp fuse would be ok? interested in replies however.
Mike Bellis |
Sep 25 2016, 04:17 PM
Run the 5A, if it blows bump up to 7.5A. Your fuse should be 125% of the circuit load value, unless you want to use the locked rotor current but that is only required for fire pumps... (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis |
Sep 25 2016, 04:20 PM
I should also mention, your fuse needs to be sized for FLA (full load amperage). Electric motors make full torque at startup. This will cause a current spike as the motor starts.
porschetub |
Sep 25 2016, 04:32 PM
Run the 5A, if it blows bump up to 7.5A. Your fuse should be 125% of the circuit load value, unless you want to use the locked rotor current but that is only required for fire pumps... (IMG:style_emoticons/default/biggrin.gif) Thanks Mike,I think that was running current so a 7.5 it is (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th April 2024 - 06:16 PM |
