Relay board fuse change, want to downsize |
porschetub |
Sep 25 2016, 03:29 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have looped heater blower fan wiring to use for oil pressure circuit,want to downsize fuse from 25amp to just run a carter rotary LP carb pump,can't find the specs for my pump so don't know current draw,question is 10 or 15amp???
Thanks and (IMG:style_emoticons/default/beer.gif) |
Mike Bellis |
Sep 25 2016, 04:20 PM
I should also mention, your fuse needs to be sized for FLA (full load amperage). Electric motors make full torque at startup. This will cause a current spike as the motor starts.
Lo-Fi Version | Time is now: 15th May 2024 - 03:30 PM |
