The 914 conversion, 3.3 Ltr suby upgrade |
flmont |
Sep 25 2016, 09:58 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Chris H. |
Sep 30 2016, 09:36 PM
Senior Member Group: Members Posts: 4,027 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
That's good. Then you probably want do what Kent said and replace that threaded fitting on your tank with another stock one. Bruce Stone or Garold Shaffer are good sources for that. Then you can use high pressure fuel injection hoses up front to connect to the fuel lines in the tunnel (both should be 5/16 from a FLAPS). The fuel pump mounts up front under the tank too if you use the Walbro like I did. Fits well in the stock location.
Post some pics anyway just so we see what you have for tunnel lines. |
Lo-Fi Version | Time is now: 20th April 2024 - 05:41 AM |
