> The 914 conversion, 3.3 Ltr suby upgrade
flmont
post Sep 25 2016, 09:58 PM
I hope to turn this 914 into a 300 HP sports car !!Attached Image
914forme
post Nov 23 2016, 11:35 AM
Yes it is easy to flip the stock intake.
I would disagree with the intake manifold. It helps more for the broader torque curve, but a properly tuned manifold will make more peak horsepower. It will just be across a very narrow RPM range. The advantage to IRIS is it broadens the drivability of the engine. Which helps on the street.
The manifold in question is more than likely seen on SDS' web site. The EG33 link is down. It is the same concept as the EJ22 build though, add a few runners. And they built the EG out of Aluminum.
flmont   The 914 conversion   Sep 25 2016, 09:58 PM
brant   :trophy:   Sep 25 2016, 10:08 PM
flmont   Rear trunk is in nice shape it will be getting pai...   Sep 25 2016, 10:23 PM
Mueller   Should be fun! I hope you still plan on addin...   Sep 25 2016, 10:26 PM
76-914   Scratch HOPE and replace with Blood, sweat & t...   Sep 26 2016, 07:27 AM
whitetwinturbo   :smash: :stir: :sawzall:   Sep 26 2016, 10:47 AM
flmont   Yes ,I plan to do a much larger area on the hood,o...   Sep 26 2016, 04:06 PM
Chris H.   Nice! Looks like Frank has mastered posting p...   Sep 27 2016, 10:22 AM
flmont   Hi Chris,..Iam going the smallcar route I think,.....   Sep 27 2016, 04:24 PM
flmont   I do need help with the fuel tank set-up I have ne...   Sep 27 2016, 04:26 PM
Chris H.   You have stainless lines from Tangerine Racing? Y...   Sep 27 2016, 04:41 PM
flmont   No,..not from Tangerine,..P.O installed them ,.I ...   Sep 27 2016, 08:14 PM
flmont   these are the fittings I have ??   Sep 29 2016, 08:35 AM
JustinMeier   Ooooooo... Can I come help? Problem is that I...   Sep 29 2016, 09:02 AM
Chris H.   That's it? Just the tank fittings? No tunnel...   Sep 29 2016, 09:40 AM
76-914   Pm Bruce Stone (Bdstone) to get the correct fittin...   Sep 29 2016, 12:35 PM
914forme   I'm curious about the 300HP, not sure how an E...   Sep 29 2016, 04:26 PM
flmont   Well, I only say 300 HP,..because I have heard u c...   Sep 29 2016, 06:14 PM
914forme   Well, I only say 300 HP,..because I have heard u ...   Sep 29 2016, 06:20 PM
flmont   when it comes to the gas tank fittings,.I don...   Sep 29 2016, 06:15 PM
flmont   Sorry Chris,..yes I have tunnel lines 2 ea,install...   Sep 29 2016, 06:18 PM
Chris H.   Sorry Chris,..yes I have tunnel lines 2 ea,instal...   Sep 29 2016, 09:19 PM
flmont   Yes,..once I get it to move down the street,.I wil...   Sep 29 2016, 09:00 PM
flmont   They are steel and no fittings attached at all,..e...   Sep 30 2016, 05:07 PM
Chris H.   That's good. Then you probably want do what K...   Sep 30 2016, 09:36 PM
914forme   Going AN has it's place, but it gets expensive...   Oct 1 2016, 08:52 AM
flmont   front section   Oct 2 2016, 10:43 AM
flmont   rear lines   Oct 2 2016, 10:46 AM
flmont   Thanks 914forme,..I wasnt sure I needed it,..how i...   Oct 2 2016, 10:56 AM
flmont   spoke to soon,...I ck'd website..its the fuel ...   Oct 2 2016, 11:15 AM
914forme   Yes the fuel screen, they get crude up, easy enoug...   Oct 2 2016, 11:52 AM
76-914   Also you might want to take a die and run it do...   Oct 2 2016, 01:03 PM
Chris H.   Yeps those ARE Tangerine Racing tunnel fuel lines....   Oct 2 2016, 12:25 PM
flmont   Ahh,..I didnt think of roughing the lines,..But I ...   Oct 2 2016, 12:31 PM
flmont   who makes the -6 mount,..I would at least look at ...   Oct 2 2016, 12:39 PM
flmont   Here is my next major issue some ends are terminat...   Oct 2 2016, 01:25 PM
mepstein   For about $600, my guy made a plug and play h...   Oct 2 2016, 01:38 PM
flmont   I would love that info pls,...Thanks FM   Oct 2 2016, 04:14 PM
flmont   where can I get the engine and tranny mounts neede...   Oct 7 2016, 07:56 PM
flmont   Ok,..I have the fuel tank fitting's on the way...   Oct 13 2016, 07:36 PM
flmont   Also engine brackets will be here next week,.(smal...   Oct 13 2016, 07:40 PM
flmont   Ok,..the next set of questions now A.can I use a ...   Oct 17 2016, 08:08 PM
Chris H.   Ok,..the next set of questions now A.can I use a...   Oct 18 2016, 06:29 PM
mepstein   You really decide on the shift tube once the engin...   Oct 17 2016, 08:29 PM
mgp4591   And you're not using a Subaru trans? :confused...   Oct 17 2016, 10:10 PM
flmont   correct no Suby trans..   Oct 17 2016, 10:50 PM
76-914   correct no Suby trans.. Mistake!   Oct 18 2016, 09:14 PM
flmont   OK Thanks Mepstein,..hope to have it all mocked u...   Oct 17 2016, 10:52 PM
flmont   Hi Chris,..I was curious if I could use a 914-6 st...   Oct 18 2016, 06:41 PM
Chris H.   Frank, It takes (at least) a few hours and a lot...   Oct 19 2016, 08:19 AM
914forme   :agree: You pay for shipping I'll send you a...   Oct 19 2016, 01:35 PM
mepstein   :agree: You pay for shipping I'll send you ...   Oct 19 2016, 02:35 PM
mgp4591   :agree: You pay for shipping I'll send you ...   Oct 19 2016, 03:11 PM
flmont   I would go for that deal if it was meant for me,.....   Oct 19 2016, 03:46 PM
mgp4591   I would go for that deal if it was meant for me,....   Oct 19 2016, 03:52 PM
914forme   I would go for that deal if it was meant for me,....   Oct 19 2016, 05:07 PM
Chris H.   Wow that's a huge donation Steve. GO FOR THAT...   Oct 20 2016, 07:48 AM
flmont   Even tho I saved the thread,..I cant find it now,....   Nov 2 2016, 06:51 PM
76-914   Even tho I saved the thread,..I cant find it now,...   Nov 2 2016, 06:54 PM
flmont   Ahh Yes,..Thank You Sir..!!! FM   Nov 2 2016, 06:59 PM
flmont   where can I find exhaust flanges,..I need 2 flange...   Nov 4 2016, 05:08 PM
mgp4591   where can I find exhaust flanges,..I need 2 flang...   Nov 4 2016, 05:17 PM
flmont   meaning I should not use anything before the 911 m...   Nov 4 2016, 06:49 PM
mgp4591   That will keep your backpressure to a minimum and ...   Nov 4 2016, 08:52 PM
flmont   Yes,..No problem with that,..I will certainly get ...   Nov 4 2016, 10:32 PM
914forme   You will need a different muffler, as there is jus...   Nov 5 2016, 03:04 PM
76-914   This will give you an idea of how much room you...   Nov 5 2016, 07:20 PM
mgp4591   A small hijack here - Kent, what axles are you usi...   Nov 6 2016, 03:51 PM
76-914   A small hijack here - Kent, what axles are you us...   Nov 6 2016, 09:27 PM
mgp4591   A small hijack here - Kent, what axles are you u...   Nov 7 2016, 03:07 AM
76-914   [quote name='76-914' post='2420503' date='No...   Nov 7 2016, 08:22 AM
914forme   Subaru Inside and some combo of outside Porsche CV...   Nov 6 2016, 05:23 PM
mgp4591   Sometimes asking is faster than research - Thanks...   Nov 6 2016, 05:54 PM
flmont   My next quest....is setting up the water system,.....   Nov 10 2016, 11:16 PM
mgp4591   My next quest....is setting up the water system,....   Nov 11 2016, 03:41 AM
Chris H.   My next quest....is setting up the water system,....   Nov 11 2016, 09:10 AM
flmont   Great Thanks,..!!!,....Well, I had som...   Nov 11 2016, 05:18 PM
76-914   SS or steel? If steel I would recommend using some...   Nov 11 2016, 05:33 PM
flmont   Steel,..he's had them on his for about 6 yrs I...   Nov 11 2016, 06:45 PM
Chris H.   Yeah measure those Frank. Don't think a V8 wo...   Nov 11 2016, 09:14 PM
76-914   Can't remember where I saw them. I lost all of...   Nov 11 2016, 09:17 PM
flmont   here are the Rad lines,...and they are 1" lin...   Nov 12 2016, 06:25 PM
Chris H.   Yeah those should be fine. So you just need to lo...   Nov 13 2016, 08:38 AM
flmont   Thanks Chris I will,...   Nov 13 2016, 10:25 AM
flmont   But here is another issue,..Y does these lines sto...   Nov 13 2016, 10:28 AM
Chris H.   They are shorter than the stock lines only because...   Nov 13 2016, 10:05 PM
flmont   yes, I have the 4 piece set,..Thanks,..Ill just se...   Nov 14 2016, 03:04 PM
flmont   Over the holiday weekend I will attempt to fit the...   Nov 21 2016, 07:48 PM
flmont   would there be a smaller throttle body set up to u...   Nov 21 2016, 10:49 PM
mgp4591   would there be a smaller throttle body set up to ...   Nov 22 2016, 02:23 AM
Chris H.   No way to do it with the stock intake manifold. Y...   Nov 22 2016, 07:10 PM
914forme   Yes it is easy to flip the stock intake. I would ...   Nov 23 2016, 11:35 AM
flmont   Well, The harness will be on the way soon, a day o...   Dec 19 2016, 07:19 PM
flmont   Now that I have my harness back Thanks Jeff,..I wo...   Dec 30 2016, 08:59 PM
flmont   I have more Q's about this upgrade, 1st wh...   Dec 31 2016, 01:00 PM
914forme   I have more Q's about this upgrade, 1st w...   Jan 1 2017, 09:43 PM
flmont   Plus It seems these are the fuel lines, but I did...   Dec 31 2016, 01:04 PM
flmont   And last Q for now, How do I hook up this water l...   Dec 31 2016, 01:07 PM
flmont   Ahh,...Thank You ..!! Frank   Jan 1 2017, 10:16 PM
Ncchany   How hard is this kinda swap and how costly is it?   Jan 1 2017, 11:12 PM
6 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 16th April 2024 - 03:34 AM
