The 914 conversion, 3.3 Ltr suby upgrade |
914pipe |
Jan 4 2017, 08:59 PM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
Now that I have my harness back Thanks Jeff,..I would like to know how others have installed thier's its bigger that I thought it would be,..and also what is this item that has the bracket attached and where does it mount ?? Thanks Frank The bracket thingy is the coil igniters.... (IMG:style_emoticons/default/beer.gif) |
914pipe |
Jan 4 2017, 09:04 PM
And last Q for now, How do I hook up this water line,.just run a jumper line ?? Thanks Very Much !! Frank I cap them, but is recommended to simulate the heater core circuit by a bypass line and is also recommended to place a vent valve (to leave no air trapped). (IMG:style_emoticons/default/beer.gif) |
flmont |
Jan 12 2017, 08:52 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I got lucky,..car 2500.00, engine with a 100k miles,trany adapter kit,transmission,and harness = 1500.00,.shipping to me 350.00,.then,.Radiator system and lines installed 1300.00,.finally I had to send the harness out to make sure it was terminated correctly,and fan harness that totaled 650.00 ,..So ,..total so far with some Misc. items about 6650.00. over a 2 year period.And I now need a engine mount that will total 300.00,..then exhaust system yet to be fabbed ,I have a 911 banana style muffler I intend to use also,..so now total is about 7K...FM
flmont |
Jan 12 2017, 08:54 PM
And Thank U,... 914pipe
flmont |
Feb 14 2017, 10:17 PM
when trying to install the fuel pump for my 3.3 build,..I have only found 1 factory wire in that compartment, Do I simply use a ground wire to the lid or body from the fuel pump it self,..?? TIA Frank
Chris H. |
Feb 15 2017, 07:39 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I'll look today Frank. Happen to have my fuel pump cover off. Long story involving me dropping my phone down the space between the tank and the body (IMG:style_emoticons/default/headbang.gif)
flmont |
Feb 15 2017, 11:00 PM
Oh...Great Thanks !!! Frank
Chris H. |
Feb 19 2017, 03:31 PM
flmont |
Feb 21 2017, 06:58 PM
OH..Ok,..Damn that blows ya had to pull the tank,..damn phones,..!! Thanks,..
I hate to ask I will be needed how to connect fuel lines to engine advice...Soon...Thanks !!!! so much...Frank |
Chris H. |
Feb 22 2017, 11:21 AM
No a problem. Very easy to set up the fuel lines. I actually had to pull the tank to put my fresh air box back in. Was able to fish the phone out through the fuel pump hole but could not see the ground wire through it. (IMG:style_emoticons/default/beerchug.gif)
Apr 30 2017, 05:04 PM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
took 5 seconds
flmont |
Apr 30 2017, 06:49 PM
r towle....Thanks...Iam just not that computor literiate
flmont |
Apr 30 2017, 06:52 PM
flmont |
Apr 30 2017, 06:53 PM
it hits the small car bracket and wont line up ??
flmont |
Apr 30 2017, 06:54 PM
before pic
Attached thumbnail(s) |
flmont |
Apr 30 2017, 10:27 PM
flmont |
Apr 30 2017, 10:29 PM
I thought it would be very close to the cross member not beyond it
flmont |
Apr 30 2017, 10:31 PM
914forme |
May 1 2017, 05:59 PM
Your on the right path, the idea with the small car is that you will need to cut the mount and mount it over an early style bar. I think I have detailed shots of mine in my build thread.
I made two of them (IMG:style_emoticons/default/headbang.gif) |
flmont |
May 1 2017, 06:25 PM
And I suppose that's why the oil filter wont screw on either,..I will ck that out,.I thought it was to short ,..not to long but I do fell better,I would still love a cradle..lol
Lo-Fi Version | Time is now: 5th May 2024 - 11:45 AM |
