The 914 conversion, 3.3 Ltr suby upgrade |
914forme |
May 1 2017, 06:28 PM
cradles are over rated (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
flmont |
May 1 2017, 06:50 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Well I was hoping to just bolt it in and be done,..But I can see now that's not the case ..
flmont |
May 1 2017, 08:51 PM
BUT,..My oil filter will not screw on either is that the result of the brackets being to long ??
flmont |
Jun 17 2017, 12:48 PM
I'am about to start my intake flip,I will be using the subie chip to eliminate the EGR system,and I will be using the spacer kit from X35 design.
1. I DON'T know how much of the EGR system to remove.( i dont have the chip yet ) 2. I don't know how to do the ALT bracket 3. Is there a shorter crank pulley I can install on the 3.3..??? 4. Thanks to all that can help...!!!! Frank |
flmont |
Jun 17 2017, 02:30 PM
Is this tiny bracket a safe lift point ,.I need to get engine on the engine stand
Attached thumbnail(s) |
914forme |
Jun 17 2017, 07:11 PM
yes it works fine.
flmont |
Jun 17 2017, 08:29 PM
WOW,..I would have never thought it could handle the weight,..Thank U,..!!
Any thought on my previous post about removing the EGR system..?? |
914forme |
Jun 19 2017, 07:58 PM
You use the rear hook spot, and I use a bolt up front to balance it all out.
You just block the EGR, with a steel plate, and a plug in the manifold if your using the stock exhaust manifolds. Since I did not keep the stock ECU, it might kick codes. Not sure (IMG:style_emoticons/default/confused24.gif) |
flmont |
Jun 19 2017, 10:23 PM
yes,.Iam using the stk manifolds,..and the stock ECU,..But I will be chipping the ECU to stop those codes,.
jimkelly |
Jun 24 2017, 05:35 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
are you using 914 trans?
flmont |
Jun 24 2017, 05:50 PM
Yes,..On the trans,..jim
flmont |
Jul 3 2017, 08:39 AM
flmont |
Jul 4 2017, 11:54 AM
BIGKAT_83 |
Jul 5 2017, 10:40 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Are there any companies that make original color dye's for Porsche interior color's,Plus I cant get rid of the stains on this horn pad,.any Suggestion's
Go to a auto paint store and get a couple of cans of SEM interior spray. They should have it in almost any color. These were black and have held up good for the last 15yrs. |
Chris H. |
Jul 5 2017, 11:08 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Trying to do the intake flip, not sure what stays and what goes I am guessing that U open the harness,.( more slack from harness)to reconnect ,connector's,..and then buy new generic hose to then refit them as needed,..Am I any where near correct ?? Thanks Frank You need to look at ThePaintedMans thread. He did a great job of explaining what he did. |
flmont |
Jul 5 2017, 12:15 PM
Yea, I could not remember his name/
write up from my home computer, Thanks !!!! |
AZ914 |
Jul 5 2017, 04:20 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Regarding the steering wheel, you can hit that with some SEM dye too (like the seats).
flmont |
Jul 5 2017, 06:01 PM
Thanks for the Dye tips,..Bigkat and AZ914 I will do just that,.!!! WOW 15 yrs that's great,..
flmont |
Aug 28 2017, 09:34 PM
would it be safe to mount the Subaru ECU, next the the battery just like the original ECU or should I mount inside the cabin,..I didn't really want to drill a 2 in whole in the fire wall if I didn't need to ?? Thanks ,..Frank
Chris914n6 |
Aug 28 2017, 10:34 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
would it be safe to mount the Subaru ECU, next the the battery just like the original ECU or should I mount inside the cabin,..I didn't really want to drill a 2 in whole in the fire wall if I didn't need to ?? Thanks ,..Frank My ecu isn't water tight so I ran it to the trunk thru the targa latch cup and sealed that. Also provides plenty of space for a relay/fuse panel. |
Lo-Fi Version | Time is now: 6th May 2024 - 04:48 PM |
