The 914 conversion, 3.3 Ltr suby upgrade |
914forme |
Sep 29 2016, 06:20 PM
flmont |
Sep 29 2016, 09:00 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Yes,..once I get it to move down the street,.I will then ( if I have the $$$) go after those mod's...
Chris H. |
Sep 29 2016, 09:19 PM
Senior Member Group: Members Posts: 4,023 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Sorry Chris,..yes I have tunnel lines 2 ea,installed.I belive 1 will be blocked off due to no return line right.?? No you definitely need a return line with the EG33. It has fuel injection just like the stock 914, in fact it operates at a higher pressure (not much). Post pics of your tunnel lines in the fuel tank area and at the engine bay area (front and back). Very important that we see the gas tank end to see if they have AN fittings or not. Also need to see if they are steel or just the standard plastic. |
flmont |
Sep 30 2016, 05:07 PM
They are steel and no fittings attached at all,..either end he just ran the lines,..did the peddel cluster rebuild,.and stopped,..then I bought her,...Pic's in the AM.!!
Chris H. |
Sep 30 2016, 09:36 PM
That's good. Then you probably want do what Kent said and replace that threaded fitting on your tank with another stock one. Bruce Stone or Garold Shaffer are good sources for that. Then you can use high pressure fuel injection hoses up front to connect to the fuel lines in the tunnel (both should be 5/16 from a FLAPS). The fuel pump mounts up front under the tank too if you use the Walbro like I did. Fits well in the stock location.
Post some pics anyway just so we see what you have for tunnel lines. |
914forme |
Oct 1 2016, 08:52 AM
Going AN has it's place, but it gets expensive very quickly. Read lots of $$$$$ to do correctly and for a street car, it is way over kill.
Tangerine racing carries the fuel strainer sock if you need it. Good luck with the build, one other thing you might want to consider is engine seals. It is a lot easier to do these while out of the car. In a 914 it is easier than doing them in the SVX. I know this from experience (IMG:style_emoticons/default/headbang.gif) |
flmont |
Oct 2 2016, 10:43 AM
flmont |
Oct 2 2016, 10:46 AM
flmont |
Oct 2 2016, 10:56 AM
Thanks 914forme,..I wasnt sure I needed it,..how is it installed,..??
flmont |
Oct 2 2016, 11:15 AM
spoke to soon,...I ck'd website..its the fuel screen, correct,..????
914forme |
Oct 2 2016, 11:52 AM
Yes the fuel screen, they get crude up, easy enough to check if you need one. All you need is hose, like Chris suggested. And a new fitting for under the tank.
BTW, the small car mount is available as just the mounts - just have to call them. It is what I used on mine. First version as a -4 style using early -4 bar. Second version went to the firewall. Like a Patric Motorsports -6 mount. It is a -6 after all. Makes it easier to get the clearance to put the EG in with out cutting the trunk. Chris did the flipped manifold on his conversion. I had room but never do anything the easy way. :headband: Also you might want to take a die and run it down the outside of the lines. Gives the hose a little something to grab onto. They just have to be roughed up a bit. Most people don't have beading tools to make them proper. (IMG:style_emoticons/default/shades.gif) |
Chris H. |
Oct 2 2016, 12:25 PM
Yeps those ARE Tangerine Racing tunnel fuel lines. Good news there. The Walbro pump mounts up front in the stock location as I mentioned. 5/16 high pressure FI hose...get plenty so you can leave some slack if you want to pull the tank up without undoing the lines.
Got your PM, I will send some pics of my mount setup. The -6 mount setup is a great way also. Even more room. |
flmont |
Oct 2 2016, 12:31 PM
Ahh,..I didnt think of roughing the lines,..But I will for sure now,..I do intend to flip the intake,..the guy from the svx site is making spacers again ,..So Iam waiting for him,.. to get a set,...
flmont |
Oct 2 2016, 12:39 PM
who makes the -6 mount,..I would at least look at it..??
76-914 |
Oct 2 2016, 01:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,453 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Also you might want to take a die and run it down the outside of the lines. Gives the hose a little something to grab onto. They just have to be roughed up a bit. Most people don't have beading tools to make them proper. (IMG:style_emoticons/default/shades.gif) You can also barely flare the end of the tube in lieu of a bead. Barely being the operative word here. (IMG:style_emoticons/default/beerchug.gif) |
flmont |
Oct 2 2016, 01:25 PM
Here is my next major issue some ends are terminated and some are not,..I really need a plug and play harness,..But, I also want to try and pin my original chassis harness to accept parts of this SVX harness is that even possible ?? (IMG:style_emoticons/default/wacko.gif)
Oct 2 2016, 01:38 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
For about $600, my guy made a plug and play harness for my svx harness and the fan on the radiator
flmont |
Oct 2 2016, 04:14 PM
I would love that info pls,...Thanks FM
flmont |
Oct 7 2016, 07:56 PM
where can I get the engine and tranny mounts needed for my 3.3 conversion,..they used to be called sport mounts but I just see regular engine mounts listed on pelican,..?? TIA, FM
flmont |
Oct 13 2016, 07:36 PM
Ok,..I have the fuel tank fitting's on the way Thanks BDstone...Now when I was taking off the the old fitting it was hard to turn,.so I WD-40 it for about 5 days ,.then it twisted off,.but it wasn't really threaded on all the way ,..so when I install my newer fittings do they screw on easy or are they suppose to have some resistance?? I don't want to strip those threads tank or fittings..TIA FM
Lo-Fi Version | Time is now: 28th March 2024 - 05:50 AM |
