The 914 conversion, 3.3 Ltr suby upgrade |
flmont |
Aug 6 2018, 09:35 AM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Yea,...Guy its horrible,.. way too hot in the carport to do anything even if you start at 4:30 AM it blows,.Iam going to have to set up A AC system if I expect to get anything done..!! And Thanks for the wire info !!
flmont |
Aug 7 2018, 02:28 PM
The Spal people say that the 10" fans are 10 Amps and Ill be running 2 the GXL wire is on the way..!! Thanks Guy
flmont |
Aug 8 2018, 12:41 PM
flmont |
Aug 11 2018, 04:11 PM
Well after setting the engine inplace with the coldwater cradle set up I can NOT install the Air intake at all,..So as Chris H said that cradle will NOT work So now back to the small car mount I hate wasting that kind of money on useless parts
Aug 11 2018, 04:45 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Many guys make a hatch in the firewall on a Porsche 6 to get access to the fan. Would you consider modifying your firewall to make things fit. Even George’s 916 was modified to fit an a/c compressor.
76-914 |
Aug 11 2018, 05:00 PM
Well after setting the engine inplace with the coldwater cradle set up I can NOT install the Air intake at all,..So as Chris H said that cradle will NOT work So now back to the small car mount I hate wasting that kind of money on useless parts I'll bet that you can sell it for more than you paid. (IMG:style_emoticons/default/beerchug.gif) |
flmont |
Aug 11 2018, 08:52 PM
Well I have only drilled 3 holes so far,..So Not yet,..iam hoping to slide it back a bit,..
how far back can it be moved before I have axle issues,I would like to try that first and use tranny hangers |
Chris914n6 |
Aug 11 2018, 08:59 PM
Jackstands are my life. Group: Members Posts: 3,303 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
It's 1.5" back on V8 swaps and 1.5" forward on mine, but that's with 914 cvs.
flmont |
Aug 11 2018, 09:24 PM
thanks chris914n6,..I think I will be using 911 CV's along with sway away axel's to match they have the ability to float a little bit,I know I can shave the intake tubes and the rubber air intake a little bit and gain maybe 3/4 of a inch .
Mepstein can I cut and then fiberglass the black intake tube to fit the firewall and still get the air volume required to run the engine as intended,... |
mgp4591 |
Aug 12 2018, 01:36 AM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Frank, if you end up using the cradle and don't want to use the Smallcar mounts, I'd probably be interested... jus' sayin'.... (IMG:style_emoticons/default/shades.gif)
flmont |
Aug 12 2018, 10:56 AM
Well..I stopped the small car cradle build and bought a Coldwater,I should have just did what ChrisH did and save myself, But small car sent me there style and it did not fit around the oil filter then they said use a smaller filter but NO its bent all wrong for a EG33 ,unless they sent me the wrong one which I now will call them,to the point the small car is still just 2 brackets and not a real cradle...
mgp4591 |
Aug 12 2018, 05:01 PM
Well..I stopped the small car cradle build and bought a Coldwater,I should have just did what ChrisH did and save myself, But small car sent me there style and it did not fit around the oil filter then they said use a smaller filter but NO its bent all wrong for a EG33 ,unless they sent me the wrong one which I now will call them,to the point the small car is still just 2 brackets and not a real cradle... And their mount was sold as the one that fits the EG33? That's strange that it wouldn't fit - maybe they sent you the EJ by mistake?? (IMG:style_emoticons/default/confused24.gif) |
flmont |
Aug 13 2018, 10:42 AM
Yea Iam going to check that out today..
flmont |
Aug 13 2018, 05:02 PM
Well I think Iam going to cheat and cut my air box and glass it back,I don't need to remove to much just the corners,..?? I hope fiberglass will stick to it,..
914GT |
Aug 13 2018, 06:46 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Frank, is it made out of ABS plastic? Possible to heat it up with a heat gun and reform it for clearance?
Chris H. |
Aug 13 2018, 08:34 PM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Well I think Iam going to cheat and cut my air box and glass it back,I don't need to remove to much just the corners,..?? I hope fiberglass will stick to it,.. You will also most likely have to trim the upper aluminum coolant hose since it was only an inch or two from the firewall on my car. Probably not a huge deal but just FYI. |
flmont |
Aug 13 2018, 10:30 PM
Thanks Guy,..Good Idea...
and ChrisH..Thanks for the heads up,Iam starting to get serious so I hope its not this much of a pain the whole time,.?? LOL Frank |
Chris H. |
Aug 14 2018, 09:49 AM
Thanks Guy,..Good Idea... and ChrisH..Thanks for the heads up,Iam starting to get serious so I hope its not this much of a pain the whole time,.?? LOL Frank Well that's the thing...it's an amazing engine but it does take a lot of little tweaks to get it into a 914 and get it running well. Once you get it right though it's really great. Probably the closest thing to an air cooled Porsche 6 there is. Also you may want to try flipping the intake around the other way. Mine fit much better with the intake pointed towards the passenger side. |
914forme |
Aug 14 2018, 05:50 PM
Well..I stopped the small car cradle build and bought a Coldwater,I should have just did what ChrisH did and save myself, But small car sent me there style and it did not fit around the oil filter then they said use a smaller filter but NO its bent all wrong for a EG33 ,unless they sent me the wrong one which I now will call them,to the point the small car is still just 2 brackets and not a real cradle... And their mount was sold as the one that fits the EG33? That's strange that it wouldn't fit - maybe they sent you the EJ by mistake?? (IMG:style_emoticons/default/confused24.gif) Nope my last one was just like that, but I am using a filter adapter, remote mounting filters, accusump, and T-Stat, and that will allow for an oil cooler if I ned one. I thought about bending it on a press brake, but then just went that route. I would say Small car has an issue with QC on that batch. Before you weld it up make sure you have a solution. |
flmont |
Aug 14 2018, 06:27 PM
I'am kinda doing 2 things reworking my cold air intake to fit against the fire wall and will now do the small car set up but I think I want to cut the ends off of the small car mount shorten it and then reweld the pieces ( because they have bolt holes) then bolt that to a new cross member,.that will also give me more room for the shift rod. ALL of this is to keep my axels in the stock 901 location,I don't want CV and axel issue's on my road trips,.!! that's my plan now could change by tomorrow.
Lo-Fi Version | Time is now: 23rd April 2024 - 10:07 PM |
