The 914 conversion, 3.3 Ltr suby upgrade |
flmont |
Aug 17 2018, 05:50 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Well I did then realized that wont work like I thought it would, So the small car mount will now be used,Iam getting a cross member made from the original 914 cross member and then I will get that installed and get everything marked and lined up then have it all welded ,As long as all that works out Ill be ready for the wiring and fuel so I'am hoping to try and start it by labor day weekend ,which would be to good to be true !!
914forme |
Aug 17 2018, 06:54 PM
Sounds like a plan
flmont |
Aug 24 2018, 01:00 PM
Has anyone ever made a homemade Intake system successfully
My crude drawing would show 180 deg. silicone tubes from throttle body then in to a cylinder with appropriate vacuume attachments ,and then a cone filter on the end... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
Chris914n6 |
Aug 24 2018, 02:58 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
How about 180 into the factory plastic box - little fab needed.
Or you could do ABS tubes, kinda generic looking but easy to work with. Also if it was mine I'd go straight back and not 90 towards the battery. |
flmont |
Aug 24 2018, 03:07 PM
Yea I tried the 180 with the original intake but it was to hi and I could not close the hatch,if I could run it straight back I would Iam not sure if there is room back there for the filter ..Etc
flmont |
Aug 24 2018, 03:10 PM
Yea well actually out of air box I could do 45 Deg,could I do 1 tube to the left and 1 to the right ?? as long as I have the same volume of air should be ok..
Chris914n6 |
Aug 24 2018, 04:52 PM
I removed the cross brace from my lid with no ill effect. Do you still have the rain tray mounted?
914forme |
Aug 24 2018, 05:20 PM
You could possible just save a bit off the stock intake couplers and gain enough to clear.
If it was me I would mark the firewall and move it just a tad with one of these (IMG:style_emoticons/default/smash.gif) Sometimes simple is just better, and if you want to take it back to original then it is easy with a bit of (IMG:style_emoticons/default/sawzall-smiley.gif) and a (IMG:style_emoticons/default/welder.gif) Easy enough (IMG:style_emoticons/default/confused24.gif) Or you can spend some time getting a forearm work out with hammer and dolly and slappers etc.. |
flmont |
Aug 24 2018, 05:21 PM
Yes,.But the whole assembly was higher than the mounting bracket on the fire wall/bulk head for the lid so I knew it was way tall
but removing the bracket may be helpful still Thanks |
flmont |
Aug 24 2018, 05:26 PM
I guess I could do (1) 3 " tube into the top of the factory box,.and just have the tube mandrel bent as needed..huh.
76-914 |
Aug 24 2018, 05:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,482 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Is that just a breather box? Any sensors in it?
Chris914n6 |
Aug 24 2018, 06:07 PM
flmont |
Aug 24 2018, 06:36 PM
Yea,..Kent just the breather box I cut the big fat 3 " pipe of the end of it to make it fit as I wanted it to,too keep my axels in line,
and Yes Stephen Iam not against massaging that bulk head a bit,.but if I cut it then I wonder if my back pad and seat would fit correctly... which I will be looking at all that tomorrow to see how bad it may be or not . Yes Chris I intend to do that tomorrow,.. Thanks Guys.. |
flmont |
Aug 24 2018, 06:39 PM
I remember ChrisH. saying that his car ran better when he put is Original intake back on,..he had some aftermarket intake system,..so Iam trying to stay as close as possible to the SVX set up.
flmont |
Aug 24 2018, 06:47 PM
914forme |
Aug 24 2018, 08:04 PM
IT would with the stock ECU.
I am going to build a center manifold with 6 equal runners, one large TB off a Shelby Mustang and the runners will have Velocity stacks ends like the current M3/M4 does. And running some form of aftermarket EFI, I only have 3 different ones on the shelf to choose from and I really don't think I like any of them. (IMG:style_emoticons/default/laugh.gif) The issue with the stock SVX unit is the variable chamber and the running was done for that manifold. If the IRIS system is not functional, it can cause some odd flat spots. ITBs would work also, but have all the issues of ITBs. But would sound so good and look even better (IMG:style_emoticons/default/drooley.gif) |
Dr Evil |
Aug 24 2018, 09:24 PM
Send me your transmission! Group: Members Posts: 22,993 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I made a full custom setup for the bus on the Corvair. Same concept would work on an SVX, but it takes time and trial and error. I the plenum volumes correct, too.
flmont |
Aug 24 2018, 09:31 PM
Yes,.I looked at Jenvey's at fox injection they only have a listing for the 3.0,.2600.00 denaro's for the stacks
flmont |
Aug 24 2018, 09:35 PM
Yes Dr.Evil,..if I stick with the tube lenth and its 3" diameter with all the vacuum ports it should work even if I did 2 intake tubes into the box as long as I have the air volume...I think it could work out
76-914 |
Aug 25 2018, 09:11 AM
Another approach, Frank. I used this set up. A silicone elbow and use the existing air temp sensor with it.
Lo-Fi Version | Time is now: 18th April 2024 - 12:13 AM |
