LED's vs Incandescent Lighting, Some data and discussion |
pbanders |
Sep 28 2016, 12:12 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
OK, I think I'm "finished" with my LED conversion on my car. I converted nearly every light in the car to LED's. Only lights I didn't convert were the fresh air fan indicator, and the non-illumination lights in the dash cluster. Headlights are WHDZ LED 7" from Amazon, all other bulbs from superbrightleds.com. Total cost including shipping and tax was $304. I originally tried H4 LED conversion bulbs but didn't like them, and went with the WHDZ lights instead, which meet my needs. I also converted my fog/driving lights to LED, the lights I bought were $14 a pair from Amazon, so including those brings me to $318.
My purpose was twofold: better lighting, and lower current draw. I hoped with the lower current draw that issues I've had with parasitic alternator drag pulling down the idle with the lights on would be improved. Both goals were definitely accomplished. With the stock incandescent lights, if you have the lights on and you're using the low beams, the current draw from all of the lights (marker lights, F/R parking lights, headlights, license plate lights, trunk light, instrument lights) is 19.5 A at 12.8 V. Replacing those lights with the LED's I described above results in a current draw of 5.0 A, a reduction of 14.5 A (~75% reduction). For the first time since I've owned this car, turning on the lights has no effect on the idle. You could probably do the same thing by changing the alternator to a 70 A or the 160 A conversion, but you wouldn't get the improvement in lighting and it would likely cost a lot more. I can even turn on the fresh air blower, heater, or windshield wipers with the lights on at idle - though I think if I turned them all on simultaneously that would be pushing my luck too far. The lighting is vastly improved. The marker and parking lights are far brighter, as is the reverse lighting (actually useful, now). I can see things in my trunk. My interior light actually lights my interior. My instrument markings are white now and not a dull yellow. I need to build a PWM dimmer for them that works off of the dimmer knob, as right now, they're "on" or "off" (kind of how LED's work with DC voltage). Headlights are vastly improved. They're so white that when I see cars with halogen lights they look like kerosene lanterns. I'm not a big fan of the WHDZ low beams (not as uniform a pattern as I'd like), but in combo with my fog/driving lights, they're awesome. The WHDZ high beams are excellent, great pattern and super throw. IMO, it's a good upgrade for our aging cars. Superbrightled's has a nice vehicle system that will tell you all the lights you need. You can find the WHDZ lights on Amazon easily if you search for "WHDZ", they're $64 ea. Or, you can go with the Truck-Lites (~$170 ea) or the GE Nighthawks (~$220). There are some other projector-style LED lights on Amazon if you want to go that way. Some pics below.... |
timothy_nd28 |
Sep 28 2016, 08:48 AM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I also agree with the LED market explosion over the past few years, I made a pretty good side hobby by using them in my instrument gauge lighting upgrades.
My issue would be the main headlights. The LED versions are pricey and since they did away with lead solder, this new solder stuff is pure (IMG:style_emoticons/default/stromberg.gif) The LED headlights have their own internal powersupply, and it seems the unit as a whole gets pretty hot. Since the new solder has issues with thermo-cycling, you end up with cold solder joints. How many of you guys had a bad GPU in your laptop due to this junk solder? I replaced 10 incandescent lightbulbs in my house to the new GE LED's. Its only been 8 months, and 6 out of ten have either failed (completely off) or its dim and flickering. These are failing due to the solder joints within the powersupply, very depressing. I feel we are all guinea pigs testing out these products, no one really knows how long it will last. |
pbanders |
Sep 28 2016, 10:36 AM
I also agree with the LED market explosion over the past few years, I made a pretty good side hobby by using them in my instrument gauge lighting upgrades. My issue would be the main headlights. The LED versions are pricey and since they did away with lead solder, this new solder stuff is pure (IMG:style_emoticons/default/stromberg.gif) The LED headlights have their own internal powersupply, and it seems the unit as a whole gets pretty hot. Since the new solder has issues with thermo-cycling, you end up with cold solder joints. How many of you guys had a bad GPU in your laptop due to this junk solder? I replaced 10 incandescent lightbulbs in my house to the new GE LED's. Its only been 8 months, and 6 out of ten have either failed (completely off) or its dim and flickering. These are failing due to the solder joints within the powersupply, very depressing. I feel we are all guinea pigs testing out these products, no one really knows how long it will last. Time will tell if the headlights I used (and the other lights, for that matter) are reliable in operation. At this price point, I'm taking a risk, but since these lights seem almost physically identical to the more expensive GE and Truck-Lite headlights, I suspect reliability will be similar. FWIW, I have dozens of cheap Feit LED bulbs (Costco) in my house that have been in operation for over a year, one failure so far. That's a lot better than the old Feit CFL's, which would fail regularly from ballast overeheating. I've reflowed many GPU's and CPU's in game systems and laptops due to BGA cracking. It's usually due to inadequate thermal design. In tight system like laptops it's hard to do much about it, but in more open systems you add a heatsink or fan and often prevent it from happening again. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:00 PM |
