WTB: nice horns and brackets for '73 |
BillC |
Sep 28 2016, 07:49 AM
Senior Member Group: Members Posts: 535 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Got one coming, so not looking any more. Thanks!
------------------------------------------------------------- I discovered recently that my '73 1.7 is missing the passenger-side horn assembly. Since the wires are taped up, it looks like it was deliberately removed by a P.O at some point in the past. So, I'm looking for a nice-condition horn and mounting bracket(s) to replace it. I'm willing to buy a pair of horns if necessary, but it/they need to have everything needed to install (brackets, nuts/bolts, etc.), since everything horn-related is missing from the passenger side except the wires. Thanks! |
bdstone914 |
Sep 28 2016, 03:40 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If it matters to you the horns are different frequencies. Marked on tbe back side. I might have a good one but cant check for a week as i am out of town.
BillC |
Sep 28 2016, 06:35 PM
Thanks for the info! I pulled the horn that is installed, and it's the 400 Hz version. So, I need the other one, which is 335 Hz, according to PET. I also need the mounting bolt and washer that goes along with it, although I can get those at the hardware store if I have to.
As mentioned earlier, I'm willing to buy a pair of horns, if y'all don't want to break up a set. |
zambezi |
Sep 29 2016, 10:38 AM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Another point is that not all 914's came with two horns. The factory taped up the unused wires and tucked them up when the second horn was not installed. That is how my car was delivered.
BillC |
Sep 29 2016, 12:38 PM
Another point is that not all 914's came with two horns. The factory taped up the unused wires and tucked them up when the second horn was not installed. That is how my car was delivered. Really? Hmm, that's interesting. Kinda makes sense, since I can't see why a PO would want to remove one horn. How can I tell if it came with two horns or only one? My 914 is a base-model '73 1.7, built in April '73. What year & trim level is yours? |
bdstone914 |
Sep 29 2016, 12:48 PM
Another point is that not all 914's came with two horns. The factory taped up the unused wires and tucked them up when the second horn was not installed. That is how my car was delivered. Really? Hmm, that's interesting. Kinda makes sense, since I can't see why a PO would want to remove one horn. How can I tell if it came with two horns or only one? My 914 is a base-model '73 1.7, built in April '73. What year & trim level is yours? I think it was the 75-76 cars that came with one horn. 1970 - 1972 cars had horn covers attached with screws. Later horns had rivets attaching the cover. No functional difference but if it were for a 914-6 the owner would want it ti be correct. |
Tom_T |
Sep 29 2016, 05:54 PM
Another point is that not all 914's came with two horns. The factory taped up the unused wires and tucked them up when the second horn was not installed. That is how my car was delivered. Really? Hmm, that's interesting. Kinda makes sense, since I can't see why a PO would want to remove one horn. How can I tell if it came with two horns or only one? My 914 is a base-model '73 1.7, built in April '73. What year & trim level is yours? I think it was the 75-76 cars that came with one horn. No Bruce, & for Bill's benefit - The dual horns was an option for all model years, & it was included in the Appearance Group of options (AG) - so by default since almost every `76 was a 2L loaded with options/AG & had the dual horns. Bill, you should check your new car window sticker, dealer BoS (new) or COA to see if yours originally came with the AG - & some 914s came with some options of the AG, but not the AG. So just seeing chrome bumpers & the sail vinyl with "chrome" trim, etc. doesn't equate to AG, since they can all be added individually. If you don't have any of the above docs, then you can order your COA from PCNA & get a $10 discount by mentioning their ad in Panorama or Excellence, or $20 IIRC if you're a PCA member (there is also a discount if you have the window sticker & send a copy with the COA app.). Since you described your 73 1.7 as: "A "stripper" car, no options." - I'd guess it only had the one horn, as was common on the 1.7s. Of course you can add the 2nd horn now, if you want them both. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
BillC |
Sep 30 2016, 06:51 AM
No Bruce, & for Bill's benefit - The dual horns was an option for all model years, & it was included in the Appearance Group of options (AG) - so by default since almost every `76 was a 2L loaded with options/AG & had the dual horns. Bill, you should check your new car window sticker, dealer BoS (new) or COA to see if yours originally came with the AG - & some 914s came with some options of the AG, but not the AG. So just seeing chrome bumpers & the sail vinyl with "chrome" trim, etc. doesn't equate to AG, since they can all be added individually. If you don't have any of the above docs, then you can order your COA from PCNA & get a $10 discount by mentioning their ad in Panorama or Excellence, or $20 IIRC if you're a PCA member (there is also a discount if you have the window sticker & send a copy with the COA app.). Since you described your 73 1.7 as: "A "stripper" car, no options." - I'd guess it only had the one horn, as was common on the 1.7s. Of course you can add the 2nd horn now, if you want them both. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Thanks for the info, Tom. (IMG:style_emoticons/default/beer.gif) I do have the COA and the dealer bill of sale, but not the window sticker. The COA doesn't have much info, and basically just says "no info recorded" except for engine serial and paint color. The bill of sale just says "914", and nothing else about the car except the VIN. I'm quite certain my car didn't come with the appearance group -- black bumpers, no sail trim, no fog lights, no fog light switch, no center console, basic steel wheels, etc. As near as I can tell, this car has no factory-installed options at all. It does have a period-correct radio, but I'm pretty sure that was dealer installed. Considering how many knucklehead SUV and minivan drivers there are around here who just can't seem to see a small yellow car, I would like to add the second horn. I've already updated the lighting to LED all around (thanks, Spoke!) to make the car more visible, now I'd like to update the horns to make it more audible. Especially since it's just a bolt-on and the car's already wired for it. Thanks, Bill |
BillC |
Oct 2 2016, 06:08 PM
Bump.
Still looking for a low-tone horn (335 Hz). |
BillC |
Oct 19 2016, 08:30 AM
Bump. Still looking.
Anyone? |
GaroldShaffer |
Oct 19 2016, 02:55 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I have this one. tested and works great. Nice clear sound. PM sent
Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 24th April 2024 - 12:07 AM |
