TURBO 4, looking for info. |
Mueller |
Oct 6 2016, 03:49 PM
Something like this,but with a type 4,auxiliary head cooling via oil/water/glycol. https://www.youtube.com/watch?v=-HltZrFGJ4U (IMG:style_emoticons/default/smile.gif) Easy to blow the heads off the flat four,a real careful build can keep it together. / That the Harley Davidson patent drawing? Amazing how small the water channels are on those yet I think it allowed a full point of compression increase. |
veekry9 |
Oct 6 2016, 04:43 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
cfd,fea,now with cooling loop,about M8,bigger is better. The flow rates keep the seat cool,so,a similar tubular coolant path around the ex-port will allow heat to be soaked away. There is room there under the port for such a tube,the sizing at the minimum,the shape a smooth curve,turbulence free. (IMG:style_emoticons/default/smile.gif) / |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:54 PM |
