Lost Power, No Fuel, Help! |
Nogoodwithusernames |
Oct 4 2016, 02:30 PM
Member Group: Members Posts: 236 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
We are up and running, with the new pump I think fuel pressure is off now, but it's running again. I pulled it out of the shop and around front to park it out of the way and it's a bit jumpy and has a slightly unsteady idle so I'll check on that later, just wanted to share that it's alive again! (IMG:style_emoticons/default/piratenanner.gif)
Thanks for the help on this everyone. |
Oct 14 2016, 01:39 PM
Everything is back to normal, guess there was a kink in the return line under the tank somehow but got that sorted so fuel pressure is normal again.
I get some hesitation right off idle, any ideas? At a quick look all the vac lines appear to be connected still. |
Perry Kiehl Clone |
Oct 14 2016, 04:17 PM
Unregistered |
I just saw this thread, and my first thought (when I read the title) was crimped or kinked fuel line.
Some fuel hoses can have a sharp enough bend to be kinked and still look OK. |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:50 PM |
