priming new fuel pump to injectors |
surfdogskier |
Sep 28 2016, 06:04 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
So I just installed a new electronic fuel pump. All lines got drained when I took the old one off. How do you go about primeing those lines with fuel. I can crank it with starting fluid but there is no gas getting to the injectors and it will eventually shut down. Is there a trick to it?....Thanks in advance.
napasteve |
Sep 28 2016, 06:35 PM
914 driving winemaker Group: Members Posts: 503 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
Do you know that the fuel pump is pumping fuel? I had a situation where the hose under the fuel tank was kinked so that the fuel pump could not get any gas.
surfdogskier |
Sep 28 2016, 07:04 PM
Do you know that the fuel pump is pumping fuel? I had a situation where the hose under the fuel tank was kinked so that the fuel pump could not get any gas. When I disconnected the original fuel pump and filter, it drained my tank pretty much. I don't see there being any kinks. It flowed out pretty steady. I didn't know if there would be air pockets that didn't allow gas to flow or not. Didn't know if I should disconnect a line going to the engine to release air or generate fuel going to the engine. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:14 PM |
