priming new fuel pump to injectors |
surfdogskier |
Sep 28 2016, 06:04 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
So I just installed a new electronic fuel pump. All lines got drained when I took the old one off. How do you go about primeing those lines with fuel. I can crank it with starting fluid but there is no gas getting to the injectors and it will eventually shut down. Is there a trick to it?....Thanks in advance.
PlantMan |
Sep 29 2016, 11:01 PM
Member Group: Members Posts: 435 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
I did the same thing recently and mounted my pump to the firewall.
In my haste I hooked-up the pump incorrectly so when I cycled the pump through the ignition it was actually running backwards. Obviously running backward will not suck any fuel. Once I corrected the wiring and turned the ignition the pump immediately sucked fuel and pressurized the system. The car started on the next turn. Investing in a pressure gauge to add to the fuel rail is worth the money to trouble shoot the system too. Make sure your pump is hooked-up correctly.....they will run backwards too.... |
surfdogskier |
Sep 30 2016, 08:28 AM
I did the same thing recently and mounted my pump to the firewall. In my haste I hooked-up the pump incorrectly so when I cycled the pump through the ignition it was actually running backwards. Obviously running backward will not suck any fuel. Once I corrected the wiring and turned the ignition the pump immediately sucked fuel and pressurized the system. The car started on the next turn. Investing in a pressure gauge to add to the fuel rail is worth the money to trouble shoot the system too. Make sure your pump is hooked-up correctly.....they will run backwards too.... I will confirm that today. Thank all of you for all the advice. That's what makes this forum the best out there....... (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:24 PM |
