More HP - what is the low hanging fruit? |
wayner |
Sep 28 2016, 06:47 PM
Newbie Group: Members Posts: 45 Joined: 25-July 16 From: Canada Member No.: 20,223 Region Association: None |
I've got a 1975 2.0 engine on carbs.
Engine is in good shape, but I might go to a 6 in the future. In the mean time where are the biggest HP bangs for the buck for my 2.0? (Assume everything is stock other than the carbs, and going back to fuel injection is not an option) Thanks in advance |
messix |
Sep 28 2016, 06:56 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
tune up and valve adjust
back date the heavy bumpers get non '75-76 heat exchangers/exhaust. learn to enjoy the momentum driving experience |
wayner |
Sep 28 2016, 07:49 PM
tune up and valve adjust back date the heavy bumpers get non '75-76 heat exchangers/exhaust. learn to enjoy the momentum driving experience Good ideas +check +check +soon ( great idea) -need more around town zip (it's great in the twisty hills) What's next on the scale of cost to benefit? |
Coondog |
Sep 28 2016, 07:54 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Take it to Orignal Customs in Grand Rapids MI........... (IMG:style_emoticons/default/smile.gif)
Sep 28 2016, 08:01 PM
Tangerine Racing header. With the heat exchanger option if you need window defogging.
Be sitting down when you check the prices. Skill like Chris' does not come cheap. --DD |
Sep 28 2016, 08:11 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What's next on the scale of cost to benefit? Weight, both yours and the car. Given the stock HP numbers every pound of weight reduction will give you free HP ... (IMG:style_emoticons/default/bye1.gif) |
matthepcat |
Sep 28 2016, 08:39 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Agree ^^
My 1.3 torque-less rotary felt a marked difference shedding the late bumpers. Both handling and exceleration. Bolt on power is probably headers and re-tuning your carbs for less back pressure. |
wayner |
Sep 28 2016, 08:42 PM
What's next on the scale of cost to benefit? Weight, both yours and the car. Given the stock HP numbers every pound of weight reduction will give you free HP ... (IMG:style_emoticons/default/bye1.gif) The car will be a fibreglass fender& bumpered GT so weight is gone ( and I'm skinny) So, what can I do to the engine short of a fire breathing monster? My last one was a Raby 2316, but I don't want that level of investment, I just want to wake it up a bit Maybe take a zero off the price of a full blown RAT motor Looking for engine ideas. What do they respond best to? I could go cam, heads, displacement and compression but together that gets pricy. What my incremental staring point without diving into the deep end again? The header and carb tuning suggestion is a good example. I'll do that. I might even stop there What's next just above that. Just cam? Clean up heads? Is there much to be gained there alone or will it require a bunch more parts to make the cam work? Or is shaving the heads for a small boost in compression a better idea than a cam? Other? Or is much more fruitless for the cost/ effort without doing everything? |
audio_file |
Sep 28 2016, 09:03 PM
Member Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest |
Ignition. At the very least pertronix, next step Mallory type ignition system or some kind of upgraded dizzy to get the best, most consistent spark you can. Won't be huge gains, but it's an easy and fairly inexpensive way to get the most out of what you have.
Cam will make a noticeable difference, as would flat top pistons (euro spec mahles) but then you're getting into splitting the case... |
Bob L. |
Sep 28 2016, 09:37 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Bump it up to a 2056 along with the head work and exhaust.
wayner |
Sep 28 2016, 09:55 PM
Well that looks like the bases are covered. Thanks!
I have an MSD box recovered from an earlier project. I don't know why I hadn't thought of using that I'll have to educate myself on Pistons in case I go that far.nothing crazy though, it's got to be reliable, and I don't want the expense of new jugs |
abes914 |
Sep 28 2016, 10:19 PM
Member Group: Members Posts: 366 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California |
How about getting lighter wheels and summer tires...
Or even lighten up your flywheel? Those are part of my wish list |
Sep 28 2016, 10:33 PM
My last one was a Raby 2316, but I don't want that level of investment, I just want to wake it up a bit. Talk to McMark from Original Customs, he has a stock 1.7L with a turbo kit that he put together. That thing is a blast to drive ... (IMG:style_emoticons/default/driving.gif) |
McMark |
Sep 29 2016, 07:25 AM
Thanks Coondog and Andy. (IMG:style_emoticons/default/beerchug.gif)
Aftermarket FI and a turbo kit will wake it up nicely. |
Coondog |
Sep 29 2016, 08:07 AM
Thanks Coondog and Andy. (IMG:style_emoticons/default/beerchug.gif) Aftermarket FI and a turbo kit will wake it up nicely. Fiqured I owed you.... (IMG:style_emoticons/default/biggrin.gif) |
VaccaRabite |
Sep 29 2016, 10:12 AM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Web 494 cam and matching lifters
96mm KB flat top pistons. Bore out your stock jugs. 2L valves. No head gasket. Eurorace header. 90% of your money will be in the heads. This was my engine before I started the EFI project. It was decidedly woke up VS a stock 2L. These days you can get way better heads done through Len's shop. Zach |
wayner |
Sep 29 2016, 10:31 AM
Thanks! While aftermarket rods are nice, is there a practical power and Rpm limit that the stock rods are safe within? |
McMark |
Sep 29 2016, 10:47 AM
Stock rods are fine as long as you're not pushing the RPM limit.
wayner |
Sep 29 2016, 10:54 AM
I'm starting to wonder if my plans will look like this:
Stage 1 - exhaust and ignition Stage 2 - sell,off my 2.0'heads, get some better ones and just do the top end ( but then I'll bet I'm not that far off the cost of a full rebuild) |
McMark |
Sep 29 2016, 11:03 AM
Yup, heads are the biggest cost. 914 2.0 heads are the best design of the stock bunch. Type4Store LE heads are the next step up, at around $2500. Add in 96mm pistons and cylinders and you're pretty much in the full rebuild ballpark.
Lo-Fi Version | Time is now: 25th April 2024 - 04:27 AM |
