Front Trunk Nose Panel, Full Panel Replacement |
TargaToy |
Nov 12 2016, 07:25 AM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
There is some photos here. I think start on page 2. (IMG:style_emoticons/default/assimilate.gif) 7 of 9. http://www.914world.com/bbs2/index.php?sho...=104128&hl= FYI> The easiest way is to leave the bucket including the drain tube attached to the front panel. Otherwise your aligning too many parts without factory jigs to hold the pieces. I'm about to start trimming the donor nose section. My car is a 72, the donor is a 73. This means that the 73 section has the added corner braces in the nose. I had in mind to remove these and utilize only the parts that matched my 72. Am I correct in my thinking? I realize that if I leave them "as is" and install the section in the car, somebody in the future may take a peek in the trunk and notice they aren't correct for the year. This might also scream "crash repair" to someone knowledgeable. On the other hand, I sort of like the additional bracing plus the trunk floor sits so nicely on them vs the way it sits in the 72. I probably know what I SHOULD do... Any thoughts on this? |
jmill |
Nov 12 2016, 08:07 AM
Check out the thread in my sig. I replaced the PS fender and nose piece.
Cairo94507 |
Nov 12 2016, 09:46 AM
Michael Group: Members Posts: 9,734 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I would just ask if you are building a Concours car or a just nice driver. If it is going to be a driver, I would leave the '73 front clip as is - I also like the added support. Also, you have documented the front clip replacement (as Scotty did on my car) and that is a part of the cars history now. It's not like you are ever going to represent the car has never had any panel replacement/body work. The more important fact, at least for me, is that it is done correctly. That looks like a nice clean clip too.
porschetub |
Nov 12 2016, 04:12 PM
OMG that's bent,wonder how the car steered after that hit,keep up the good work,the solution you have is the best and easiest,good luck.
TargaToy |
Nov 12 2016, 08:06 PM
This was my dad's car so I never plan to sell it. Eventually, it'll pass to one of my kids, God willing. I guess I'm just wondering if even a well done repair like I'm planning could hurt the car's value--presuming 914 prices continue to climb.
jmill |
Nov 12 2016, 08:33 PM
Expecting a 40 year old car to have never had rust or seen an accident is a pipe dream. The only thing that really counts is the quality of the repair. A high quality repair detracts little to no value whereas a poor quality one can detract thousands or make the car worthless.
Lo-Fi Version | Time is now: 6th May 2024 - 05:20 PM |
