WTB - Coil Mounting Bracket, The one on the fan housing |
sdoolin |
Oct 2 2016, 12:57 PM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Looking for the bracket that locates the ignition coil to the fan housing (as opposed to the engine tin above cyl #4).
euro911 |
Oct 2 2016, 03:08 PM
Check with Bruce (bdstone914) ... he might have some re-plated ones.
bdstone914 |
Oct 3 2016, 05:32 AM
I might have some but cant check until i get back home. The tin mount bracket can be re shaped on the end to fit the fan shroud.
sdoolin |
Oct 3 2016, 07:21 AM
I might have some but cant check until i get back home. The tin mount bracket can be re shaped on the end to fit the fan shroud. Thanks Bruce, if you could check when you get back I'd appreciate it. I will have the thing powder coated so no need for super shiny. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:59 AM |
