Clutch Slips on 6 conversion |
Catorse |
Oct 2 2016, 03:16 PM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
So here's the deal:
- built 2.7 with Webers. All the tricks possible on this motor - rebuilt trans - new flywheel (not resurfaced!) - new 914 clutch - New TOB - new clutch cable Cable is adjusted so that engagement point is as close to the floor as possible. When I go above 4000 RPM, I get some serious clutch slip. So bad I can't really climb higher, although the car has a 7K limit. I'm thinking the stock 914 clutch can't hold it, even though it is a brand new clutch. Any ideas here? I do not believe it is making enough power to overwhelm the stock clutch, unless the stock clutch is super weak. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:30 AM |
