MicroSquit Conversion, Giving this a try |
Mblizzard |
Oct 3 2016, 07:18 AM
I am pretty happy with my stock FI. But after seeing some of the setups at Okteenerfest, I thought this might be worth trying.
The stock system is not easy to modify and get things running correctly. I spent a lot of time making minor adjustments by trial and error. While I am not looking for huge HP gains or anything, it is pretty clear that the mods I have could potentially benefit from a bit more precise control. Going to start with fuel only at this point to get things going and see where it leads me. Any help or suggestions for set up would be appreciated. |
Mblizzard |
Oct 3 2016, 11:15 AM
Still asking questions. A number of people have confirmed that the stock CHT will work with this system. Because this system is a bit more sensate to noise it is designed to have the grounds loop back to the unit or essentially use a 2 wire sender. Of course the stock CHT is a single wire that is grounded directly to the engine.
Most of the modern 2-wire units are 3/8 NPT and the stock CHT is 10 mm x 1. Very close I know but has anyone ever seen a 10mm x 1 to 3/8 NPT adaptor? |
jcd914 |
Oct 3 2016, 04:50 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Still asking questions. A number of people have confirmed that the stock CHT will work with this system. Because this system is a bit more sensate to noise it is designed to have the grounds loop back to the unit or essentially use a 2 wire sender. Of course the stock CHT is a single wire that is grounded directly to the engine. Most of the modern 2-wire units are 3/8 NPT and the stock CHT is 10 mm x 1. Very close I know but has anyone ever seen a 10mm x 1 to 3/8 NPT adaptor? I believe the 911 3.2 CHT is 10mm x 1.0mm and the later one "(1988 on? ) were 2 wire harnesses, including a ground wire. Jim |
Lo-Fi Version | Time is now: 26th April 2024 - 04:55 AM |
