MicroSquit Conversion, Giving this a try |
Mblizzard |
Oct 3 2016, 07:18 AM
I am pretty happy with my stock FI. But after seeing some of the setups at Okteenerfest, I thought this might be worth trying.
The stock system is not easy to modify and get things running correctly. I spent a lot of time making minor adjustments by trial and error. While I am not looking for huge HP gains or anything, it is pretty clear that the mods I have could potentially benefit from a bit more precise control. Going to start with fuel only at this point to get things going and see where it leads me. Any help or suggestions for set up would be appreciated. |
jd74914 |
Oct 4 2016, 06:19 AM
Its alive Group: Members Posts: 4,777 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Does the Dakota CHT gauge have any analog (voltage) outputs? The actual CHT sensor is a type K thermocouple, so you'll need an amplifier to read it into the ECU. I've used some of the cheap amplifiers on eBay for small projects and been pretty happy with them.
Mario @ TheDubShop has a pretty slick crank trigger setup which isn't too expensive. If you're going for simple to start you can go wasted spark/injection with just that crank trigger. I would do some looking into controlling ignition too (I know you have the cool A123 dizzy) because once you start modifying injection you're probably going to want to jump right into modifying ignition too. (IMG:style_emoticons/default/smile.gif) |
Mblizzard |
Oct 4 2016, 11:01 AM
Does the Dakota CHT gauge have any analog (voltage) outputs? The actual CHT sensor is a type K thermocouple, so you'll need an amplifier to read it into the ECU. I've used some of the cheap amplifiers on eBay for small projects and been pretty happy with them. Mario @ TheDubShop has a pretty slick crank trigger setup which isn't too expensive. If you're going for simple to start you can go wasted spark/injection with just that crank trigger. I would do some looking into controlling ignition too (I know you have the cool A123 dizzy) because once you start modifying injection you're probably going to want to jump right into modifying ignition too. (IMG:style_emoticons/default/smile.gif) Correct on the Type K and the voltage output is in the mV range so not very useful as is. Contacted Dakota and they don't have an way to output the voltage. So nice thought, difficult to implement. |
Lo-Fi Version | Time is now: 26th April 2024 - 08:16 AM |
