MicroSquit Conversion, Giving this a try |
Mblizzard |
Oct 3 2016, 07:18 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I am pretty happy with my stock FI. But after seeing some of the setups at Okteenerfest, I thought this might be worth trying.
The stock system is not easy to modify and get things running correctly. I spent a lot of time making minor adjustments by trial and error. While I am not looking for huge HP gains or anything, it is pretty clear that the mods I have could potentially benefit from a bit more precise control. Going to start with fuel only at this point to get things going and see where it leads me. Any help or suggestions for set up would be appreciated. |
McMark |
Oct 6 2016, 07:37 AM
I don't think MicroSquirt does sequential injection. Just batch. Pair the cylinders like the factory did for the injection harness 1/4 and 3/2. This is better for injectors, but WRONG for ignition.
I tried using a signal from a distributor a long time ago and never got it to trigger reliably. When I would crank, the RPM readout on the laptop would jump all over, varying wildly, and illustrating how hard of a time MS was having reading the coil signal. When I installed a crank trigger setup, it was rock solid, even under just cranking. So much better. The distributor based wheel may work well. It's not ideal, and I haven't used one, but I can't think of any reason it wouldn't work well enough. |
Lo-Fi Version | Time is now: 18th April 2024 - 01:11 AM |
