MicroSquit Conversion, Giving this a try |
Mblizzard |
Oct 3 2016, 07:18 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I am pretty happy with my stock FI. But after seeing some of the setups at Okteenerfest, I thought this might be worth trying.
The stock system is not easy to modify and get things running correctly. I spent a lot of time making minor adjustments by trial and error. While I am not looking for huge HP gains or anything, it is pretty clear that the mods I have could potentially benefit from a bit more precise control. Going to start with fuel only at this point to get things going and see where it leads me. Any help or suggestions for set up would be appreciated. |
Dtjaden |
Oct 7 2016, 11:13 AM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
The crankshaft trigger wheel, either the DubShop's or Original Customs', goes between the crankshaft and the fan. It does not space the fan out farther so I don't believe it would have any impact on an A/C fan pulley.
Using the crank sensor wheel does give you the opportunity to implement FI first and add ignition later. A cam (distributor) based RPM sensor forces you to do both FI and ignition at the same time. |
Lo-Fi Version | Time is now: 19th April 2024 - 06:07 PM |
