MicroSquit Conversion, Giving this a try |
Mblizzard |
Oct 3 2016, 07:18 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I am pretty happy with my stock FI. But after seeing some of the setups at Okteenerfest, I thought this might be worth trying.
The stock system is not easy to modify and get things running correctly. I spent a lot of time making minor adjustments by trial and error. While I am not looking for huge HP gains or anything, it is pretty clear that the mods I have could potentially benefit from a bit more precise control. Going to start with fuel only at this point to get things going and see where it leads me. Any help or suggestions for set up would be appreciated. |
N_Jay |
Oct 7 2016, 11:20 AM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
Maybe I am not picturing it correctly, but how does it go between the crank and fan and NOT space the fat out further?
It would seem a Dist trigger wheel could easily have two missing teeth and give you the same trigger as a crank wheel, but could also give you came timing should you ever want sequential FI and/or not run wasted spark. P.S. Not arguing, just asking to learn. |
jd74914 |
Oct 7 2016, 11:26 AM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Maybe I am not picturing it correctly, but how does it go between the crank and fan and NOT space the fat out further? There is a thick washer under the fan that gets replaced. (IMG:style_emoticons/default/smile.gif) |
N_Jay |
Oct 7 2016, 11:59 AM
Maybe I am not picturing it correctly, but how does it go between the crank and fan and NOT space the fat out further? There is a thick washer under the fan that gets replaced. (IMG:style_emoticons/default/smile.gif) I don't recall, but have not built a Type4 in over 20 years. I was looking for an easy way with minimum engine rework. |
Lo-Fi Version | Time is now: 23rd April 2024 - 12:11 PM |
