MicroSquit Conversion, Giving this a try |
Mblizzard |
Oct 3 2016, 07:18 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I am pretty happy with my stock FI. But after seeing some of the setups at Okteenerfest, I thought this might be worth trying.
The stock system is not easy to modify and get things running correctly. I spent a lot of time making minor adjustments by trial and error. While I am not looking for huge HP gains or anything, it is pretty clear that the mods I have could potentially benefit from a bit more precise control. Going to start with fuel only at this point to get things going and see where it leads me. Any help or suggestions for set up would be appreciated. |
cgnj |
Oct 10 2016, 11:50 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
waited till I had something of value to add.Grabbed a few ac pulleys and I don't see any cranktrigget that uses the locating pin will not support the stock ac pulley. So your AC choices are trigger wheel in distributor, Mark or thedubshop trigger wheel, plus this from dlee http://www.914world.com/bbs2/index.php?sho...=192917&hl= Carlos |
Mblizzard |
Oct 10 2016, 12:23 PM
Hi, waited till I had something of value to add.Grabbed a few ac pulleys and I don't see any cranktrigget that uses the locating pin will not support the stock ac pulley. So your AC choices are trigger wheel in distributor, Mark or thedubshop trigger wheel, plus this from dlee http://www.914world.com/bbs2/index.php?sho...=192917&hl= Carlos Just heard from Mario. No go on the mini cam. it uses a crank trigger. Will likely use my stock dizzy, locked out on advance, with Petronix to get signal to ECU. Made some progress. Wired in MAP sensor yesterday. |
Lo-Fi Version | Time is now: 18th April 2024 - 11:23 PM |
