MicroSquit Conversion, Giving this a try |
Mblizzard |
Oct 3 2016, 07:18 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I am pretty happy with my stock FI. But after seeing some of the setups at Okteenerfest, I thought this might be worth trying.
The stock system is not easy to modify and get things running correctly. I spent a lot of time making minor adjustments by trial and error. While I am not looking for huge HP gains or anything, it is pretty clear that the mods I have could potentially benefit from a bit more precise control. Going to start with fuel only at this point to get things going and see where it leads me. Any help or suggestions for set up would be appreciated. |
N_Jay |
Oct 10 2016, 04:54 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
Is anyone using a MAF sensor or an O2 sensor with there MS setup?
If so, which ones, mounted how? |
Mueller |
Oct 10 2016, 10:04 PM
Is anyone using a MAF sensor or an O2 sensor with there MS setup? If so, which ones, mounted how? No need for a MAF, you use the map sensor. Pretty much any newer WB02 sensor, the manuals should have the recommended and proven units. (buy a new one, don't cheap out on used) http://www.megamanual.com/PWC/ RTFM (IMG:style_emoticons/default/smile.gif) |
jd74914 |
Oct 11 2016, 05:57 AM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Is anyone using a MAF sensor or an O2 sensor with there MS setup? If so, which ones, mounted how? No need for a MAF, you use the map sensor. Pretty much any newer WB02 sensor, the manuals should have the recommended and proven units. (buy a new one, don't cheap out on used) http://www.megamanual.com/PWC/ RTFM (IMG:style_emoticons/default/smile.gif) 14point7 makes some very reliable, low cost O2 sensor controllers. I've had better luck with them than Innovate products over the last few years and they are much cheaper to boot! (IMG:style_emoticons/default/smile.gif) I would recommend getting a Spartan 2 over an Innovate LC/LM/1/2/etc. or any of the AEM products. http://www.14point7.com/products/spartan-lambda-controller-2 |
Lo-Fi Version | Time is now: 25th April 2024 - 10:18 PM |
