914-6 GT oil line specs, WTF (W hat's T he F inal) opinion on size of front cooler lines |
forrestkhaag |
Oct 5 2016, 03:59 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
I am wondering if anyone has a good spec on the ID/OD for the two brass lines running to and from the front oil cooler? See Pix from P-Base for reference / I will be using AN fittings at the working ends for my flexible connections to the cooler and the thermostat and oil tank etc.. And does anyone know generally what the oil pressure is (hot) going to the front oil cooler??
I could also makes kit-sets for other installations if anyone is interested / Once I know how the factory did the job and I can accurately replicate the same or similar quality and product..... Thanks in advance for the input. (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
stugray |
Oct 7 2016, 07:06 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I have a slightly related question:
Can I use 5/8" Aluminum tube (10-AN like this: https://www.summitracing.com/parts/sum-g2558/overview/) for high pressure (up to ~100 PSI) oil lines? You can flare the tubing and add AN fittings. I was wondering if I could replace a maze of 10-AN fittings and braided stainless hose with some of this. I know that Al Tube is acceptable on aircraft for oil, but is it a different type? |
Lo-Fi Version | Time is now: 17th May 2024 - 09:59 PM |
