914-6 GT oil line specs, WTF (W hat's T he F inal) opinion on size of front cooler lines |
forrestkhaag |
Oct 5 2016, 03:59 PM
I am wondering if anyone has a good spec on the ID/OD for the two brass lines running to and from the front oil cooler? See Pix from P-Base for reference / I will be using AN fittings at the working ends for my flexible connections to the cooler and the thermostat and oil tank etc.. And does anyone know generally what the oil pressure is (hot) going to the front oil cooler??
I could also makes kit-sets for other installations if anyone is interested / Once I know how the factory did the job and I can accurately replicate the same or similar quality and product..... Thanks in advance for the input. (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
Harpo |
Oct 8 2016, 07:52 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I really like the idea of the hand bent aluminum lines for my 4. Although I do wish it was a bit larger.
David |
stugray |
Oct 8 2016, 12:48 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I really like the idea of the hand bent aluminum lines for my 4. Although I do wish it was a bit larger. David The largest I can find in coils is 5/8" (10AN). If you wanted to run larger mostly straight runs, I think we would need to buy straight tube and weld AN fittings to the ends. Aircraft spruce seems to have a good selection of both straight tube and coil (versatube): http://www.aircraftspruce.com/catalog/mepa...03versatube.php |
Lo-Fi Version | Time is now: 18th May 2024 - 01:44 AM |
