Diagnosing an intermittent D-Jet problem..., Hesitation under load at 2800 RPM but only when cold... |
MikeInMunich |
Oct 10 2016, 02:46 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Hi again from Munich!
Here are the details. But please see update from Feb. 5th below! I have a D-Jetronic intake. Under load and at about 2800 RPM Im experiencing an intermittent hesitation. Yesterday my son and I took the car out for a drive from Munich, towards Innsbruck and back and we ran into a bit of rain coming along the Aachensee (lake), and this hesitation got worse. Then I remembered the only other time I've had this car out with 100% humidity and that it wasn't running well on that day either, so this is apparently a clue. So what can this be? And why does it happen at all, even when it's not raining, albeit not as noticeably? Is there a cure? Experts / senior gurus out there, thank you for your time and sharing your knowledge and experience, in advance! With kind regards, Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
StratPlayer |
Dec 8 2016, 11:21 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I was having that problem,,,hesitation,,,,, I just replaced the TPS board and the problem is solved.... No more hesitation at all.
Lo-Fi Version | Time is now: 19th May 2024 - 01:02 AM |
