Diagnosing an intermittent D-Jet problem..., Hesitation under load at 2800 RPM but only when cold... |
MikeInMunich |
Oct 10 2016, 02:46 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Hi again from Munich!
Here are the details. But please see update from Feb. 5th below! I have a D-Jetronic intake. Under load and at about 2800 RPM Im experiencing an intermittent hesitation. Yesterday my son and I took the car out for a drive from Munich, towards Innsbruck and back and we ran into a bit of rain coming along the Aachensee (lake), and this hesitation got worse. Then I remembered the only other time I've had this car out with 100% humidity and that it wasn't running well on that day either, so this is apparently a clue. So what can this be? And why does it happen at all, even when it's not raining, albeit not as noticeably? Is there a cure? Experts / senior gurus out there, thank you for your time and sharing your knowledge and experience, in advance! With kind regards, Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
914_teener |
Feb 14 2017, 02:38 PM
914 Guru Group: Members Posts: 5,200 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
So did you do everything Brad noted?
I would suggest methodical checklist approach.. |
MikeInMunich |
Feb 14 2017, 03:28 PM
So did you do everything Brad noted? I would suggest methodical checklist approach.. That was awesome of Brad to take the time to type up such a long list, and yes, most, though not all of those things were checked. It was quite exaustive. I'm pretty sure that it's either the TPS or a bad connection, likely at the CHTS. Just wondering right now if anyone has a clue as to why the symptom would stop when the car is fully warm. Thanks, M.i.M. |
Lo-Fi Version | Time is now: 27th May 2024 - 08:55 AM |
