Diagnosing an intermittent D-Jet problem..., Hesitation under load at 2800 RPM but only when cold... |
MikeInMunich |
Oct 10 2016, 02:46 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Hi again from Munich!
Here are the details. But please see update from Feb. 5th below! I have a D-Jetronic intake. Under load and at about 2800 RPM Im experiencing an intermittent hesitation. Yesterday my son and I took the car out for a drive from Munich, towards Innsbruck and back and we ran into a bit of rain coming along the Aachensee (lake), and this hesitation got worse. Then I remembered the only other time I've had this car out with 100% humidity and that it wasn't running well on that day either, so this is apparently a clue. So what can this be? And why does it happen at all, even when it's not raining, albeit not as noticeably? Is there a cure? Experts / senior gurus out there, thank you for your time and sharing your knowledge and experience, in advance! With kind regards, Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
MikeInMunich |
Feb 15 2017, 01:50 AM
Update: Disconnected the TPS today and tested...Problem was still there. So this rules out the TPS, correct?
Then I checked the CHTS connection. I'm pretty darn sure it must be good. As previously mentioned, the Ohm test on that was well within parameters, over 2000 at ambient temp and under 300 after engine running until warm. So I guess I will now have to go through Brad's entire list after all. M. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:43 AM |
