intermittent starter crank whe turning key 73 2.0 |
rosenfe |
Oct 12 2016, 12:16 PM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
i turen key and get fuel pump on,no crank at starter,if i retry key, it usually will crank and start.i have replaced ignition switch(white plastic switch afew months ago and it worked at that time).new starter and battery,pushing on wires at switch under dash does not change intermittent starting.would a bad ignition tumbler cause this?my key is pretty worn.
Lo-Fi Version | Time is now: 17th May 2024 - 04:47 AM |
